Old 01-19-2026, 08:59 PM   #1
IT Cowboy
IT Cowboy's Avatar
Place to buy a Highlander plaid bench cover
My OCD is getting the best of me and I want to change my embossed parchment seat to the plain with plaid inserts. I have searched here but the info seems a bit dated so I thought I would ask. I found the place to purchase the plaid material and a local upholsterer quoted me $1400 to make and install. That might be the going rate but I thought I would check. I did find one that was @600 for just the cover with plaid but it had embossed center and sides.
Any leads or references where to look.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
