Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-27-2026, 01:39 PM   #1
Jesse72
Active Member
Jesse72's Avatar
61GMC Parts 305/Hydromatic/Auto Column Dana44 Wheels
Hi guys selling parts from my 61 that I bought out of California. Im doing a restomod and don’t need any of this.
All this stuff can be picked up on Avon Ohio 44011. I can ship some of the smaller stuff but not the big stuff.
Motor Transmission and Column. 305/ Hydromatic with factory GMC w/ auto column. Small dent/ hole from damage in the column, I am assuming something hit it at one point. I found the broken piece inside it so it could be repaired. The column and linkage is rare. Motor and transmission are cores, have been off the road for a long time. I do not want to separate.
$800
4 Factory 15” 3 clip wheels and a 5th newer style nub wheel. I believe the 3 clip wheels are the as the 55-59 and early 60s. The hubcap style is the same. Very clean, from southern California. Tires are rollers.
$475
60-62 GMC Dana 44 I believe it to be a posi. It’s dirty and crusty, has been off the road for 40+ yr. It turns freely but I have not opened it up. Trailing arm style.
$200
Factory Trailing arms, nice shape off california truck. $200
60-62 Suburban and Panel Truck homemade hitch
$50
Jesse
72 4x4 Sold
59 GMC air ride ls swap
61 GMC 1001 Carryall
Jesse72 is offline   Reply With Quote
Old 01-27-2026, 01:42 PM   #2
Jesse72
Active Member
Jesse72's Avatar
Re: 61GMC Parts 305/Hydromatic/Auto Column Dana44 Wheels
More pictures
Jesse
72 4x4 Sold
Old 01-27-2026, 10:31 PM   #3
bhap
bhap's Avatar
Any idea what the ratio is on the Dana axle?
bhap is offline   Reply With Quote
Old 01-27-2026, 11:05 PM   #4
Jesse72
Active Member
Jesse72's Avatar
I do not, it needs to be pressure washed and cleaned up but it's about 5degrees out and a foot+ of snow so i haven't gotten into it. I have read that some have a 3.54 but I cannot confirm. I do know both wheels turn when i turn the pinion so its got a posi.
Jesse
72 4x4 Sold
Old 02-12-2026, 04:04 PM   #5
MusicMan70
MusicMan70's Avatar
How much for the double groove pulley set up on the crank?
Thank you
Shipping to 92881 CA
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-12-2026, 07:43 PM   #6
Jesse72
Active Member
Jesse72's Avatar
Thank you
I am trying to keep the motor transmission and steering column all together at this point. I can let you know if I part it out.
Jesse
72 4x4 Sold
Old 02-15-2026, 10:38 AM   #7
Jesse72
Active Member
Jesse72's Avatar
The Dana 44 is a 3.07 posi
Jesse
72 4x4 Sold
