Old 02-16-2026, 11:19 AM   #1
UniqueOdyssey68
UniqueOdyssey68's Avatar
Sanden "mini" compressor custom lines? w/Vintage Air?
Does anyone know if custom lines are required on Sanden SD7B10 "mini" low mount compressor when using vintage air? (Gen 4) Why and what lines?
I was told this but cannot understand why or what lines specifically need to be "custom" made. And what lines I cannot use in the vintage air kit, or what to use. Confused. It looks like I should be able to use everything in the kit though..
The SD7B10 mini compressor fitting on top is a -8 and -10 tube O-fitting, so isn't that the same connection as what is in the vintage air lines?
Everything in the vintage air instructions mentions the same tube sizes.
https://vintageair.com/content/751171.pdf
This is related to the older revived thread about the dirty dingo low mount AC bracket kit which is great, and uses this smaller compressor
https://www.67-72chevytrucks.com/vbo....php?p=7731654
- long term project '68 C10 true shortbed! Resto-mod. LS swap. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=769919 "I've still kept this project truck when anyone else would've given up and sold it as is. Giving up is easy, staying the course is part of life's journey"
___________________________________________
'68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor
UniqueOdyssey68 is offline   Reply With Quote
Old 02-16-2026, 12:12 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Sanden "mini" compressor custom lines? w/Vintage Air?
Have used the Sanden compressors multiple times with Vintage Air units. Never had a problem as VA systems use the standard -6, -8, and -10 hoses & fittings. I don't use the VA hose kits and buy my hose & fittings from Cold Hose https://coldhose.com/ .
Helpful hint: make sure the fittings and hose are from the same manufacturer. Have had issues with leaks when mixing and matching fittings from one vendor and hose from another.
Willie Makeit is offline   Reply With Quote
Old 02-16-2026, 10:05 PM   #3
UniqueOdyssey68
That's a big help, thank you! I won't worry about it yet, since I'm just in the mockup stages of my build, cab and firewall holes, and wire harness, before body/paint.
From what I could tell looking at all the parts in the kit, it was likely the hose part of the lines that might need to be custom made for length, due to the compressor being lower mounted/farther away, compared to a high mount.
Contacted Vintage Air support, (surprised they were open today) and I have the MOD hose kit, which provides extra hose and one end isn't crimped, allowing custom fitment. So FYI if anyone uses the low mount compressor, w/vintage air, get the MOD hose kit.
Old 02-17-2026, 09:31 AM   #4
A1971Blazer
A1971Blazer's Avatar
I made custom lines for mine mainly because I wanted it all neat and compact.
The suction line is a hard line, bent and mated to the hose.
I also used the reduced barrier hose and fittings. It's much smaller in diameter than the standard hose. My buddy has the crimping tool for the lines.
I didn't use any of the hoses that came with the VA kit.
The ports on my compressor are different from the ones you show in your photo.
This is after it was finished. The compressor is almost completely out of sight.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-17-2026, 01:18 PM   #5
Shifty One
Shifty One's Avatar
I made mine also (87 V20 with Sanden), bought the parts at Genuine Parts Co./NAPA.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Shifty One is online now   Reply With Quote
Old 02-18-2026, 08:45 AM   #6
Joyridin
I made mine also. It looks similar to yours. VA has a kit for LS, but it didn't match where I had my compressor mounted if I recall.
I think I just bought the hose and fitting and I had a crimping tool, so it was relatively easy.
Joyridin is offline   Reply With Quote
Old 02-26-2026, 11:47 PM   #7
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I used VA EZ-Clip system on my 70 K10 build. The lines are smaller and easier to work with. I like it much better then bead lock and you can do it yourself in your own garage. I wouldn't use anything else. You can check in my build thread.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
