1969 front headlights
Hi all, I’m trying to adjust the headlights on my 69.
I see the X-axis and y-axis adjustment screws but that doesn’t seem to be the issue. The issue is that the headlights are totally off center from the bezels/grill, probably 1/4” (the headlights would need to move outward in order to center the headlight in the bezel. Appreciate any input on this, thank you!
1969 C10 Shortbed |
![]() Join Date: Jun 2005
Re: 1969 front headlights
Please post pics so we can better help you.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
![]() Join Date: Apr 2016
The truck was not engineered to have tolerances within 1/4 inch. Anywhere on the truck.
Sure thing
Appears the headlamp needs to move outward by about 1/8 - 1/4”. Same on the other side.
1969 C10 Shortbed |
20' Daredevil (Ret)
![]() Join Date: May 2003
Yeah, that doesn't look right. Makes me think there's an issue with the mounting of the headlight buckets.
![]() Join Date: May 2002
Are you sure that the black bezels are on the correct sides?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
No not sure, that’s how the truck came.
I guess I can swap and see. Interesting that his is happening on both sides (headlight needs to move outward in both cases)
1969 C10 Shortbed |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
You should be able to see both adjustment screws past the cutouts on the bezels. If so, they are on the correct side(s).
#10 | |
I guess it wouldn’t hurt to just swap the two bezels to rule out the previous owner putting them on the wrong side. Do the headlight buckets have any adjustment at all?
1969 C10 Shortbed |
![]() Join Date: Jun 2022
Y adjuster is above the headlight, X screw is towards the centerline of the truck(also towards my finger if that helps ;-) )
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
Somehow the shadows on black on a grey day didn't make the most compelling image
This is driver's side
#13 | |
Do you see at the bottom of yours, there’s a rounded side. My rounded side is on the right. That leads me to believe they very well could be swapped accidentally. Will check
1969 C10 Shortbed |
#14 | |
Just another adventure in forensic restoration ;-)
#15 |
My pic is the driver side
So my expectation is that they need to be swapped and rotated 90deg Will report back soon. Edit: turns out the two sides were swapped by previous owner. I swapped them this evening and the gap improved. The joys of discovering things on your 56yr old pickup lol Thanks for the help guys!
1969 C10 Shortbed Last edited by Luke87gt; 02-18-2026 at 11:39 PM. |
#16 |
I'm glad it was a simple fix.
#17 |
Likewise!
That’s a clue for others. If your headlights seems to be too far inward on both sides, check that the bezels are not swapped from side to side. Good luck all!
1969 C10 Shortbed |
#18 |
By the way, wondering if you guys have any recommendations for some bright aftermarket headlights that still look close to oem.
The amount of light these stockers give out is flat out dangerous lol
1969 C10 Shortbed |
#19 |
First, put in a relay kit first. Your existing bulbs will be much more effective with a full 12V
I went ahead and put in basic parts-store halogens(Sylvania SilverStar IIRC) Whiter and brighter, but still look authentic(see above pic ;-) )
#20 |
Here's an A/B comparison for what the relays will do. Yes, the lights are on in the first pic.
![]() https://67-72chevytrucks.com/vboard/...d.php?t=782071
#21 |
Headlights do get dim after some decades. I like Sylvania or Wagner H6024 Basic sealed beam halogen headlights. Walmart was stocking them but looks like they are out of stock right now. Typical price is $12 to $16 each or car parts store $20+. The fancy ones like SilverStar or XTRAVision are slightly brighter but burn out much more often.
https://www.walmart.com/ip/Sylvania-...-Pack/16913604 https://www.amazon.com/dp/B0006H8QIU?th=1 https://www.oreillyauto.com/detail/c...f-1/syl0/h6024 |
#22 | |
![]() Join Date: Nov 2013
At full charging voltage, they're getting 13.5-14.5 volts straight from the alternator output. I made a load center for the LS swap so I just put the headlight relays right into it. I used a breaker rather than fuses for the headlights. The terminal block is for all the LS wiring. I have to remove the bezels to adjust them.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
#23 |
I too installed self-resetting breakers. One for high beam, one for low
#24 | |
#25 | |
It has a cover that latches on, there's room for 2 spare relays and a little bag of extra fuses
| Bookmarks |
