Old 02-17-2026, 12:32 AM   #1
General23cmp
Door window frame tight at front
Tried to attach photos, but it wouldn’t let me. Something about a security token, and I tried logging out and back in.
I have my gaps (approx 3/16”) and body lines looking reasonably good for a first look. I even leveled the truck side by side using a laser level, and both doors’ body lines are at the exact same level compared to each other. All looks good. The issue is that my passenger door window frame is very tight along the front angle and at the top front corner. The driver’s side looks good, if anything, wider than I’d prefer. What is the best way to open the right one? I feel the rest of the door is placed well. If I lower the door, my body lines get off. If I slide it back, the rear gap tightens. I measured the front edge of the door to the rear of the cab door gap, and the two sides are the same, so sliding the door back would make the two sides different.
This is a 67 truck with original doors, so perhaps they hadn’t refined them at this point. Thanks.
UPDATE: I’ve convinced myself after using a contour gauge, that the A pillars are shaped slightly differently. The inner flat area along the door’s front edge is angled differently making one have the better gap. The passenger one angles slightly toward the door so that the gap gets tighter on that angled window frame as the door is shut. I’ll need to tweak the passenger A pillar.
General23cmp is offline   Reply With Quote
