Old 02-19-2026, 04:41 PM   #1
ullose272
info and pics of c20 with axle flip
I picked up an 86 c20 that i plan on cutting down to a short bed and lowering, ive been reading that axle flipping a c20 will have different results than a c10. can anyone post some pics of a c20 with axle flip and about how much lower it is? and how much you had to notch the frame?
ullose272 is online now   Reply With Quote
Old 02-23-2026, 02:52 PM   #2
LONGHAIR
Re: info and pics of c20 with axle flip
The drop will be a little more, because of the thicker springs. They make the truck sit higher, in stock form.
At a minimum, you'll need a bolt-in notch kit. It depends on how much you intend to haul at that point. You might get by with less travel, if you don't carry much, otherwise, banging the bump stops can be pretty harsh feeling.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-23-2026, 05:24 PM   #3
ullose272
i will likely build a sort of step notch and weld it in. from the look of it the axle will be on the frame with the flip
Old 02-24-2026, 10:51 AM   #4
SCOTI
SCOTI's Avatar
It will be very close. Flip kits on 3/4 ton set-ups are typically closer to almost 8" of drop depending on how many leafs are in the pack.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-24-2026, 11:03 AM   #5
ullose272
thats fine, im going to pancake the front, spindles, and springs. see how its sitting, if its too low in the rear ill build a link setup.
Old 02-24-2026, 11:32 AM   #6
SCOTI
SCOTI's Avatar
You can also add a 'lift' shackle to raise the set-up slightly.
It's the next gen but my '99 is a 3/4 ton 8-lug w/the Semi Float 14bolt housing. I did a flip kit but it was too much drop vs the front (3" spindle + 1-coil removed from the springs). I used the lift shackles to balance it out. My Squarebody dually was going to get the same thing but I changed direction & did a 4-bar as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-24-2026, 11:42 AM   #7
ullose272
nice i'll keep that in mind! thanks
Old 02-24-2026, 12:59 PM   #8
ullose272
Old 02-25-2026, 03:16 PM   #9
ullose272
how is the bed clearance on the square bodys? my 68 gmc with a 9 inch comes pretty close to the bed, its sitting about 6" lowered in the rear.
Old 02-25-2026, 05:05 PM   #10
SCOTI
SCOTI's Avatar
I can only share my experience w/my dually & the truck it replaced (my 74swb C10) as they're the only squares I've owned....
My 74 was the 1/2 ton HD/Trailering package which had 8-leafs. Doing a flip kit on it yielded +6" of drop. With Western Chassis bolt-in C-notches, there was limited clearance (~2") but the 12bolt differential housing smacked the bed floor on significant bump/compression situations.
When I measured my dually (w/its even larger Dana housing) for a similar flip kit, there was minimal clearance as well. I recall it was less than 2" just sitting static. With that measurement & having grown tired of the constant impact experienced driving my 74, I stopped my plan to lower it until I had a solution for additional clearance. I did stepped rails (Porterbuilt units) vs. c-sections & did a raised bed floor to ensure clearance.
My dually @ ride height has never had contact issues w/the differential hitting sheet-metal (floor) or frame (@ the frame notch). Those efforts greatly improved (>100%) the driving experience vs my old 74 & I will not compromise that quality ever again. My dually has much better ride quality even w/the load rated/stiff sidewall truck tires.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
