Old 03-31-2026, 12:46 PM   #1
IT Cowboy
IT Cowboy's Avatar
How are the original AM radios mounted - do I need a brace
I have an original GM Delco AM radio I am going to put in my truck. Do I need the mounting bracket / brace for the back or will it be ok using just the front cups and shaft bolts and nuts.
Right now the radio I am wanting to put in just has one straight metal tab on the back. I can probably take a piece of metal strap and fab one up if needed or even pipe strap?
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
