need asap pinion gear 1975 -14 ff 4.10 ratio (10-41)
need a good one asap my rear bearing went out and trashed the surface it rides on
reads 1-75-3977337-10-41-6 M
you'll need to replace both the ring & pinion gears, as they wear together...if you merely replace the pinion, it will accelerate wear dramatically!! I think the cheapest way out for you is to find a complete 14 bolt FF rear and swap it all out...these can be had for between $100-$200.
ken '58 Chev NAPCO 4x4 short '60 GMC Suburban 4x4, restored '60 GMC 3/4T stepside 4x4 '64 GMC Suburban 4x4, restored '90 Chev Suburban 4x4, dually, ZZ502 '77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s '88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!) '03 Jeep Wrangler Rubicon '79 Chev 3/4 Suburban 4x4, 400-400-203 |
#5 | |
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
I know it should not be done but I am willing to deal with the fact it may only last 60-79 k instead of 150k If anyone has a set or just that gear I'm ready to buy .
I do have a complete 14 ff with 4.56 |
TTT
![]() Join Date: Jun 2003
Have an almost new set of 3.21 if interested.
72longbed ![]() ![]() ![]() |
sorry 4x4
Silverado Stew
I have a rear end out of a 3/4 ton 4x4. It is the 14 bolt and has 4.10 gears.
would you be willing to pull the front pinion out like my pic above ? remove the front 6 bolts and it will slide right out.Just leave it all together. e-me price shipped to 17329 zip in pa
Silverado Stew
Yeah, I'll pull it out. Does anybody know about what these weigh and/or what they're worth? I can get a pretty close idea on shipping if you know the weight.
I'll try to pull it out tonight, but it's snowing and blowing here pretty good right now, so we'll have to see. |
#13 |
weight is about 15 lbs . I can buy a whole rear fron the junkyard for 150.00 but I do not need the whole rear just that section. 50-60 shipped ?? let me know
