Old 02-17-2004, 07:09 PM   #1
BigDaddyCMU
Small block engine stands for a 454?
Is it possible to use small block engine stands with a 454? I believe that is what was on it when I pulled it. Is it ok to use these, or do I need the big block towers? I know they're expensive as hell.
BigDaddyCMU is offline   Reply With Quote
Old 02-17-2004, 07:25 PM   #2
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
i know that the small and big block towers are different.
i know that you can put a small block on big block stands
but i am not sure about the big block on the small block stands.
when we put the small block on the big block stands, it seemed to increase the clearance around the exhaust manifold
tommie is offline   Reply With Quote
Old 02-17-2004, 07:32 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm using the small block motor mounts and stands in my 69 K20 that now has a 454 in it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-17-2004, 08:45 PM   #4
Burnsman
Chevy Freak
Burnsman's Avatar
motor mounts
Yukon Jack, did you move the motor mounts forward so the firewall cleared the valvecovers, do you have a body lift so they cleared or? I am getting ready to do the same, but I don't have a body lift. I thought about moving everything forward. Brian
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 02-17-2004, 08:59 PM   #5
jmanz69
Careful, they attack...
jmanz69's Avatar
I think the 4X4's and 2wd's are different. Since there never was an option of a BBC in a 4X4. All you have are small block stands. I would think you could use them, but they are much smaller than the big block ones. Might bent if your engine has much umf. Just a thought
jmanz69 is offline   Reply With Quote
Old 02-17-2004, 09:34 PM   #6
john
member #16
john's Avatar
I think they will work but the BB manifolds will not. You will have to use headers.
john is offline   Reply With Quote
Old 02-18-2004, 08:38 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
John is right. The engine bolts right to the small block stands. The problem is exhaust manifold clearance.
See the dished area in the picture below on a big block stand. It's there for manifold clearance. I tried to do a big block on small block mounts once and could never find a header or manifold that would clear.
