Did GM make a ?????????????
I was wanting to know if there is a gear ratio offered for our trucks, ( 12 BOLT ) that is in between 4.11 and 4.56? I see where there is one for a Ford nine inch. Lke a 4.33 or 4.35. Let me know??
72 LWB chevy truck. Pasadena, Texas |
Try this link, the ones in red were the stock ratios the other ones were aftermarket. I would just to the Summit, or Jegs sites and see what is available.
http://my.core.com/~faldrich/axleratio.htm
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Formerly yellow72custom
The lowest gear offered in a 12-bolt i n these trucks is 4.11. You can get lower gears from the aftermarket and have them swapped in.
BTW Walker, that link you posted is for the passenger car 12-bolt, which is quite different that the truck 12-bolt. Many more ratios were offered for the car version, and i hear it is stronger too.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
It don't have to be GM SORRY I am wondering if this gear is available for our trucks 4.33 or 4.35
you can always swap a ford nine inch into your truck with that gear ratio in it. same bolt pattern. some modifications required though.
70 longbed 496/th400/Ford 9" |
