Old 02-26-2004, 11:19 PM   #1
krazy_texan
krazy_texan's Avatar
carrier bearing pic
how does a carrier bearing on a 67 model truck with a 4spd mount in there it is a GMC truck if it makes a difference
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-26-2004, 11:43 PM   #2
adamls
Gotta Startem Early
adamls's Avatar
Shouldnt it look like any other carrier bearing with any transmission? The carrier bearing mounts to the cross support that mounts the trailing arms. It does not mount near the transmission crossmember that I am aware of.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 02-26-2004, 11:44 PM   #3
neonlarry
neonlarry's Avatar
I don't know which type you have hope this helps.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-27-2004, 12:28 AM   #4
400ex
Neonlarry,
That is one sweet bearing. Is that a machined aluminum housing?
Is that your creation? If not where'd you get it?
The hanger for the bearing, is it original or just cleaned and painted?
Sorry for all the dang questions.
James
400ex is offline   Reply With Quote
Old 02-27-2004, 09:54 AM   #5
MOTHERTRUCKERS
C 10's mount bolts run inline with the driveshaft like in the picture, C 20's mount bolts run side to side.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-27-2004, 03:37 PM   #6
rn2fine
rn2fine's Avatar
Where did you get that aluminum/poly carrier bearing? I can only find the steel/poly bearing for 99 bucks at cpp. Let us know. Thanks !!!
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 02-27-2004, 03:42 PM   #7
rn2fine
rn2fine's Avatar
I just found a local shop that has the aluminum/poly bearings like the one in the picture. Price is $150. Company info below:
Dick's Drive Shaft Exchange
2750 E Mcdowell Rd
Phoenix, AZ 85008 - 3615
(602) 231-0877
68 Chevelle
Old 02-27-2004, 08:04 PM   #8
neonlarry
neonlarry's Avatar
Check here.
http://www.iedls.com/bearings.html
The hanger is original, just cleaned and painted.
