[Pic] This is where my groundstrap should be right?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
yes
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
ok...it's CUT, and I don't remember EVER cutting it, so HOPEFULLY when I replace it today, it will fix some of my small electrical problems....
Dont hook it to that spark plug wire
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
#5 | |
yeller
Is that cork on your firewall??
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Me thinks those little wire separators should mount on a bracket
5-7 dropped 87 CC Dually
Run a new Battery cable size ground from the starter to the frame.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
5 day ban, learn to behave.
since we're nitpicking, who puts PCV on the passenger side? guh-heyyy
![]() mike |
yeller
Is that a small twig or leaf jammed under the spark plug wires? :p
#11 | |
![]() Tim, it looks as if your assumtion is correct in the pic you posted. |
#12 | |
#13 | |
#14 |
[QUOTE]Originally posted by 1FaastC10
[B] why not just bolt it to the head where its supposed to go? ![]() Well Gee. You got this big pos batt. cable going to the starter wouldn't you want a nice big ground cable there too. Makes your starter roll over alot better.
#15 |
Garage Queen Material
where should i run my ground strap since i have alum. heads?
#16 |
electricity still flows through alum.
#17 |
Damn all them comments had me rolling.
BTW: Did you get the strap installed? Mine looks pretty nasty from all the oil that has leaked on it in the past. Can you buy them new from the dealer? Are there different lengths? How much do they cost?
#18 | |
#19 | |
#20 | |
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
#21 | |
Happy to be here
![]() Join Date: Mar 2000
#22 |
A good heavy flat braided ground strap from the frame to one of the bell housing bolts will work better than using an insulated cable & having it melt against the headers...corn
#23 |
so did the ground strap fix your problem?
#24 | |
#25 | |
