Old 10-15-2015, 06:13 PM   #1
68c10owner
68c10owner's Avatar
4L80E behind a 5.3
Any reason not to do this? I know the 4L80E is heavy but is it goign to rob some power from the 5.3? Planning to run a stock long block with a mild cam, headers and CAI and a 2800-3000 stall. Found a 4L80E core local for $150. I know 2 transmission guys so getting it built isnt a problem.
Anthony
68c10owner is offline   Reply With Quote
Old 10-15-2015, 07:08 PM   #2
aknovaman
Re: 4L80E behind a 5.3
Go for it. 60e trans are a consumable item if you get on it hard in stock form. Just be sure to wire harness as a 80e and use applicable PCM file. I stopped using 60e in my swaps for reliability issues.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 10-15-2015, 07:09 PM   #3
aknovaman
You can beat on a 80e in stock form and try pretty hard to break it.
FMCDH GBU and GBA
Old 10-16-2015, 01:02 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you were to dyno the same vehicle with a 60e vs an 80e, the 60e would have a little less parasitic drivetrain loss; the tradeoff being that the 80e is far stronger, enough to warrant a little extra loss.
When you start making big power, that few hp loss is worth the strength. The same applies to rear ends as well (i.e 10bolt vs 12bolt)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-16-2015, 03:44 PM   #5
boostedc10
boostedc10's Avatar
Can you do it? Of course you can. Do you need to do it? Probably not. Does it work with your budget over buying a 60e? If so go for it.
In my opinion if you have no plans for big power I would go with a 60e. They are a **** ton lighter, smaller, and have a shorter first gear.
If you stay within there limits they are just as reliable as the 80e.
Not trying to sell you on one or another but if you are not putting down some serious power then a 60 is a much better choice!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-16-2015, 09:20 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Can a 60e hold 450hp? Is it just a re-pin of the trans harness to run a 80e? I was wondering the same thing as I just got a 5.3/4l60e that I'm putting in my 40 Ford. Plan is to turbo it and aim for 450-500hp. If the 60e is not going to live, I'd rather build the frame to accept a 80 now.
Ryan
1969 Chevy milk truck
Old 10-16-2015, 09:35 PM   #7
boostedc10
boostedc10's Avatar
Totally different case and I would go 80e on any turbo build. The main reason is most people end up wanting to put more power down eventually with the boost bug.
In the end it's more of a question of the torque. At 450 you would most likely be around upper 300-low 400 on tq depending on the cam and right at the limit of a mild to fully built 60-65e. Of course I have seen plenty of built 60s stay together with over 500 ft lbs but just as many come apart. With boost or nitrous the trans takes more of a beating due to the rapid increase in power.
It's pretty much a repin to add the speed sensor and flash to go from a 60 to 80.
I'm sure Clyde will chime in too with some knowledgeable feedback, as I am sure he has done a ton of both transmissions.
Brandon
Instagram: DRVFSTR
Old 10-16-2015, 09:54 PM   #8
Dieselwrencher
Ok, thanks for the info. A lot of people I know say the 60 will live but I can't honestly say I'll not drive it hard and want more power once it's together. Everything else I have keeps progressing. I'm sure this would be the same. Are there any years 80e's that are better to start out with over others? Thanks for the help and info.
Ryan
Old 10-16-2015, 10:04 PM   #9
cableguy0
I would personally go with an 80. In completely stock stocks the 4l60e doesn't often live past 100k. If you drive hard and have extra power the 60 will die a quick and expensive death.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-16-2015, 10:05 PM   #10
boostedc10
boostedc10's Avatar
99-01 have the better sprag in them but if you are rebuilding it, anything 99 and up will work. Myself I like the 01 and up because I always go through them and they have the newer od setup.
Brandon
Instagram: DRVFSTR
Old 10-17-2015, 08:48 AM   #11
LowLifeS10
LowLifeS10's Avatar
Does the 67-72 cab need a high hump for the 4L80e to fit? And is there anything that need to change on the 5.3 so the 4l80e will work except from the pcm flash and wire harness mod?
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 10-17-2015, 10:12 AM   #12
boostedc10
boostedc10's Avatar
Yes you will need to have a high hump. If you are layed out you will have to make a few additional mods to the hump and floor. As for the swap you will also have to figure out what converter you are running. If you plan to run a stock 80 you will need the flex plate and spacer from the 6.0l. If you are going to a custom converter you can have the cover done so you can use the stock 60e stuff.
Brandon
Instagram: DRVFSTR
Old 10-17-2015, 12:06 PM   #13
ls1nova71
ls1nova71's Avatar
It may depend on where the engine is mounted, but my blue 72 had a 6.0/4l80e and had the low hump and it fit fine. There are pics in the build thread in my sig if you want to see where the engine was, but it was close enough to stock that the fan fit the fan shroud.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-17-2015, 03:20 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you change the wiring harness and plug on the side of the trans (part of a full case rebuild) then you can use the pre 99 80e's.
Old 10-17-2015, 09:21 PM   #15
clinebarger
I'm usually hesitant to engage in threads like this......
Everyone know's I like 4L60E's, When built right they can handle 450-475 rear wheel torque for a LONG time. Past this you get into hard part stressing that is just is not worth the hassle or expense.
However you have certain people that can burn up a 4L60E with 350 ft lbs in a month, Of course when they drive it's like 24hours of LeMans with stop lights, Too many repetitive WOT 2-3 Up-shifts, 3-2/4-2/3-1/4-1 Down-shifts will overheat the 3-4 Clutch!!! And cause Friction failure.
4L80E....Great unit! Dual Feeding the Directs, Lube to Line mod, Boost Valve, HD Intermediate Snap-ring, Fix the AFL & TCC regulator leaks, Set end-play, Blueprint clutch clearance & feed hole sizes....can handle 800 ft lbs.
What nobody talks about is what a 4L80E robs under the curve, Not just ratios, But the weight of the drums. I can tell the difference! The more power you have....The less this matters.
clinebarger is offline   Reply With Quote
Old 10-17-2015, 09:26 PM   #16
boostedc10
boostedc10's Avatar
Must be. I know on mine with Nates crossmember there is no way its fitting under the low hump.
On a side note yours and acks trucks were the ones that pushed me to an LS in mine. Loved how clean it was! Have you seen it since it sold at auction?
Brandon
Instagram: DRVFSTR
Old 10-17-2015, 09:31 PM   #17
boostedc10
boostedc10's Avatar
Cline I knew you would find your way to this thread. For some reason I just noticed my autocorrect turned you in Clyde lmao. I am on the same page as you. The 60e is a better choice for any mild na application.
Brandon
Instagram: DRVFSTR
Old 10-17-2015, 09:34 PM   #18
68c10owner
68c10owner's Avatar
I don't have a preference really. I don't have a transmission yet and found a core for $150 so I thought I'd ask. Not sure if I'm going to pick it up or not though. It's currently mu daily driver with a 305/700r4 and the trans is starting to go so might have to hold off on this project for a bit.
Anthony
Old 10-18-2015, 02:14 AM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
___________ The more power you have....The less this matters.
This works amazingly well as a fill-in-the-blank statement!
Old 10-18-2015, 09:44 AM   #20
Clyde65
Clyde65's Avatar
So whats wrong with being call Clyde??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-18-2015, 10:13 AM   #21
boostedc10
boostedc10's Avatar
Ha-ha, nothing if you were who I was talking about. I think auto correct likes Clyde and not Cline since its the one that made the switch on me!
Brandon
Instagram: DRVFSTR
Old 10-19-2015, 09:34 AM   #22
Heavymetl
No high hump needed. I've got a low hump and the 4L80E fits with tons of room. Easy to work on, heck I can even access all the bellhousing bolts with minimal fuss.
As for power robbing, in theory, sure. Over on ls1tech there's multiple threads of track results after switching from 4l60e to 4l80e and there's no change. Several went faster due to the more favorable ratios. Bottom line....if a 4L80E fits, in my mind there's no reason NOT to run one.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 10-19-2015, 10:18 AM   #23
boostedc10
boostedc10's Avatar
And here we go with the great forum debate.
In the end the difference is in the converter and the power the motor makes.
Brandon
Instagram: DRVFSTR
Old 10-19-2015, 10:33 AM   #24
Heavymetl
Haha sorry about that. Didn't want to start a debate. You're 100% right anyway. The converter is the key. I still stand by my statement though, for the average Joe trying to run 11s or 12s just install something reliable. The 4L80E is tough to beat from a cost/toughness/streetability standpoint.
1970 C10
11.16@121.07
Old 10-19-2015, 10:42 AM   #25
boostedc10
boostedc10's Avatar
Haha no worries, it was bound to happen.
For sure I wont argue it, I love the 80e's. Just like to make it clear that a 60e for the right price isn't a bad deal for a mild built LS.
Brandon
Instagram: DRVFSTR
