69 shortbed emergency brake cable routing
Hello does anyone have detailed pictures of how to properly run the emergency brake cables? My 2 short cables from the drums are good but the others are ripped. I’m putting my truck together so I want to make sure how they’re ran ahead of time.
Posted via Mobile Device |
#2 | |
The Older Generation
Re: 69 shortbed emergency brake cable routing
LockDoc
Here is the '67-'68 diagram. LockDoc
LockDoc nailed it, again.
If you want pics, send me your email address in a PM. The pics are too large to post to the board. |
![]() ![]() Join Date: Mar 2016
Rather than start a new thread , I'm adding a question . Can any one tell me what this part in the illustration is ? I have purchased every thing from the handle to the rear backing plates for my '67. Maybe I'm still missing something. Thanks.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
So even after I ask for help I keep looking for the answer.... And low and behold I think the picture quality is just bad . This picture makes it clear , so it appears nothing is there.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 03-20-2019 at 05:01 PM. |
Does anyone have a photo of how the cable is routed and sits under the hood of a 1970 C10 Shortbed?
Thank you
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
#8 | |
LockDoc
Thank you LockDoc,
You don't by chance have an actual photo of the way it rests under the hod, do you? Also, what do the clamps look like? I have a bag full of them and not sure what goes where at this point.
![]() Join Date: May 2010
Here are pictures of my '69 long bed. I'd expect the cowl to frame portion would be the same as a short bed.
Jim |
Thank you Jim!
Does the e-brake line go between the inner fender and the two brake lines going up to the master cylinder? Or around the brake lines?
It's rearward of the brake lines. You can also see that in the second pic of my previous post. The cable goes rearward behind the top shock mount. The brake lines run down the frame in front of the shock mount.
Jim Last edited by FirstOwner69; 05-19-2020 at 11:22 PM. |
Does anyone have pictures of the holes the twist hook goes in? My 69 long bed 2wd had all of its parking brake cables hooks etc removed before I bought it. My other question is which hole in the crossmember where the carrier bearing is mounted does it the cable go thru. Any help would be appreciated. Thanks
These may help. '69 C20. Longbed of course.
Jim Last edited by FirstOwner69; 06-07-2022 at 09:01 PM. |
#15 |
That will help a lot thank you. I see a brace in photos 2 & 3 that my truck doesnt have. That must be a difference between the C-10 frame and the C-20.
