Old 03-06-2014, 09:25 AM   #1
Caddude101
Rust repairs
OK I'm fixing to start replacing all of my rusted out floorpans, rockers, cab corners, and anything else tht needs it. Couple of questions where is the best place to buy these parts. Also is this something that a newbie should takle are not. I have built the chassic upto and including a 600 hp 454 big block. Any help or comments are appreciated.
Caddude101 is offline   Reply With Quote
Old 03-06-2014, 09:48 AM   #2
1963c-10
1963c-10's Avatar
Re: Rust repairs
Top banana has the best parts in my opinion.
1964 Short bed trailer
Old 03-06-2014, 10:01 AM   #3
Clyde65
Clyde65's Avatar
Re: Rust repairs
^^^^^I second this!!^^^^
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-06-2014, 10:34 AM   #4
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Re: Rust repairs
I'm also very happy with Top Banana. They had everything I needed in stock and it came pretty quick.
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 03-06-2014, 12:29 PM   #5
joesscamaro
Re: Rust repairs
I'm currently in the same process as you're getting ready to dive into. This has been my first time ever doing this, in depth, bodywork. Just take your time and measure everything out and take some before pictures for reference. I'm almost done with my passenger side and then I'll be jumping over to the driver's side. I guarantee you it's taken me twice as long as it should, but everything seems to be falling into place with minor modification. You don't have to do it this way, but I have just tacked everything in place, to make sure everything is fitting right, and then I'll go back and burn it all in. Just my suggestion! Have fun!
joesscamaro is offline   Reply With Quote
Old 03-06-2014, 12:42 PM   #6
Mikes66ChevyC10
Re: Rust repairs
I'm also about to dive into repairing all the rust in my cab. Never done this kind of rust repair either. Did you brace your cab up? I've looked over a lot of the build threads on this forum and some brace their cabs and some don't.
Old 03-06-2014, 02:57 PM   #7
joesscamaro
Re: Rust repairs
I didn't brace mine up because my cab is bolted to the frame. I'm not saying this is right or wrong...that's just the way I did it. I've not had any problems so far. It's been a lot of fun actually, seeing it all come back together. My pieces were from LMC and required a little massaging, but nothing major.
Old 03-06-2014, 03:07 PM   #8
Mikes66ChevyC10
Re: Rust repairs
All 4 of my cab supports are shot so I'm not really sure how I'm going to tackle it yet.
Old 03-06-2014, 03:45 PM   #9
1963c-10
1963c-10's Avatar
Re: Rust repairs
Easiest way to do the cab support is to put the cab up on end for best access. Just my opinion though.
Old 03-06-2014, 06:32 PM   #10
bj383ss
bj383ss's Avatar
Re: Rust repairs
Top Banana.
As others have said take lots of picture, measurements and your time. It is my first time doing it as well. Tack welded in my driver floor pan this morning.
Spent about an hour getting the kick panel massaged enough to line up. The kick panel has been the most out of alignment so far. And I am going to have to redrill the holes where the bottom fender bracket goes as they just don't line up at all. I did not brace my cab but it is still mounted to the frame. I measured both door openings in different spots and they are dead on.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-06-2014, 07:34 PM   #11
MikeS.
MikeS.'s Avatar
Re: Rust repairs
I bought mine from LMC, they worked well.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 03-06-2014, 10:25 PM   #12
shortbed70
shortbed70's Avatar
Re: Rust repairs
I did all the repairs on Dave's truck in my signature big red dog and they were lmc. All the info and pics are in the build. Check it out if you have questions
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
