Return vs. return less fuel rail
My 6.0 has the old style fuel rail with the return line. Is it better to use the returnless fuel rail and corvette filter/regulator or my original setup. I have access to the later style if needed.
I just finished up my frame and I ready to start my LSx swap. I got my new spectra GM11C gas tank and it doesn't have the baffle. It is the same as my original tank (GM11B). So I'm a lilttle bummed out.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
![]() ![]() Join Date: May 2015
Re: Return vs. return less fuel rail
I capped my return line on the fuel rail of my 6.0 and am running the vette filter/reg..no issues and works great.
What did you do with the vacuum diaphragm and vacuum line?
If it's in place go return. Less wear on pump bullheading less heating the fuel. Better down the road if you want more hp. All big fuel systems use a return.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
It would be easier just to stay with the return system I have and just use a fuel filter designed for it.
And better for the system,parts and performance
#7 | |
Here are mine that I recently ordered, showing the baffle. ![]() |
#8 | |
That is what I was thinking too. The new tank isn't stamped with the part number like my GM11B tank is. It only gas a small sticker on it with GM11A on it. Have no idea what GM11A tank is for.
I looked it up, it's an 80' and earlier Squarebody tank, looks to have a smaller filler neck.
I would use the return if you have it. A $10 fuel filter is way better when it comes time to change it than a $60 filter that can have a bad regulator straight out of the box. Also vacuum referenced fuel pressure versus a set pressure, so you have to tune for it. I'll never understand peoples infatuation with the returnless rail.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#11 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#12 | |
For the record, my replacement GM11C gas tank came in today. This one has the pan inside the tank and the correct 1 5/8" filler neck.
