Old 03-19-2016, 09:04 PM   #1
foamypirate
foamypirate's Avatar
Re: Return vs. return less fuel rail
Originally Posted by 65standard View Post
I got my new spectra GM11C gas tank and it doesn't have the baffle. It is the same as my original tank (GM11B). So I'm a lilttle bummed out.
It was probably boxed incorrectly. The GM11C and GM1C should definitely have baffles in them. I would return and ask for a new one.
Here are mine that I recently ordered, showing the baffle.
foamypirate is offline   Reply With Quote
Old 03-19-2016, 09:38 PM   #2
65standard
65standard's Avatar
Originally Posted by foamypirate View Post
It was probably boxed incorrectly. The GM11C and GM1C should definitely have baffles in them. I would return and ask for a new one....
That is what I was thinking too. The new tank isn't stamped with the part number like my GM11B tank is. It only gas a small sticker on it with GM11A on it. Have no idea what GM11A tank is for.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 03-19-2016, 10:16 PM   #3
foamypirate
I looked it up, it's an 80' and earlier Squarebody tank, looks to have a smaller filler neck.
Old 03-20-2016, 12:02 AM   #4
ls1nova71
ls1nova71's Avatar
I would use the return if you have it. A $10 fuel filter is way better when it comes time to change it than a $60 filter that can have a bad regulator straight out of the box. Also vacuum referenced fuel pressure versus a set pressure, so you have to tune for it. I'll never understand peoples infatuation with the returnless rail.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-20-2016, 10:36 AM   #5
Hart_Rod
Hart_Rod's Avatar
It's easy..............................................!
Hart_Rod is offline   Reply With Quote
Old 03-20-2016, 01:58 PM   #6
foamypirate
I used it because that's how my LQ9 came. $60 is way too much to pay for the filter, I got mine for $30, WIX brand.
