04-21-2007, 11:45 PM | #26 |
Re: Gear Numbers
43 / 14 = 3.0714286 (3.07)
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
04-22-2007, 03:45 PM | #27 |
Grand PooBaa Member
Re: Gear Numbers
Well seeing that I still cant get the bolt out to change axles, and I broke a $12 bolt removal tool in the hole I will be looking for the whole thing. wheels and all. Now the question s do I want to buy it new or grab one from the local pick a part. Anyone is southern cali now of a spot?
04-22-2007, 03:48 PM | #28 |
Grand PooBaa Member
Re: Gear Numbers
Also where do I add the new gear oil in the rear end?
04-25-2007, 05:55 PM | #29 |
Grand PooBaa Member
Re: Gear Numbers
Really guys, where do I put the gear oil in? Did not see any place th pour oil in.
04-25-2007, 06:22 PM | #30 |
Re: Gear Numbers
The Formula = Divide the big number by the small one and that's the gear ratio!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 04-25-2007 at 06:22 PM. |
04-25-2007, 09:34 PM | #31 |
Re: Gear Numbers
Hello all! I have a 1969 and I have not had a chance to check the rearend yet, but I read somewhere that this year truck was factory gear ratio of 3.73. with optional 3.08 or 4.11??? So does your glove box tag have an option for that gear ratio special ordered?
1969 C10 Long Wheel Base 1985 Monte Carlo SS(Snake Charmer) |
04-26-2007, 09:57 AM | #32 |
It's a catastrophic success.
Re: Gear Numbers
On the front or Yolk side of the axle there will be a squared hole pipe plug, use a ratchet to remove it. On level ground fill untill oil starts to come out the hole.
04-26-2007, 11:10 AM | #33 |
The Older Generation
Re: Gear Numbers
Another way to tell the ratio of the rear gears is by the code stamped on the passenger side tube of the rear end housing. The first picture shows the area of the housing where the code is stamped and the second picture is of the code number itself. When You have the code just use the first two or three letters ('67-'69 have two letters & '70-'72 have three) and look it up here in the axle codes section. http://www.americanclassic.com/paint.htm The letters TDE on this one tells me it is a 307:1 - 1/2 ton assembly LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-26-2007 at 11:12 AM. |
04-26-2007, 01:03 PM | #34 | |
its all about the +6 inches
Re: Gear Numbers
True, the BASE MODEL truck, came with a 3.73... however, that does not mean that the standard gear will alwaysbe 3.73. There were trannys that would come with a 4.11, and other trannys that would get you 3.07 gears. (3.08 was a car gear) Yes, if there is an optional gearset, then it would be listed, but, that doesn't mean you have 3.73's though. What engine, and tranny did your 69 come with originally? (if no engine option listed, then it was a 307 for a CE truck, and a 250 for a CS truck) Last edited by Longhorn Man; 04-26-2007 at 01:03 PM. |
04-26-2007, 01:54 PM | #35 |
Grand PooBaa Member
Re: Gear Numbers
Will an 81 chevy rearend fit my 69? Found one for 150.00 so I thought I'd ask.
