Old 08-18-2012, 05:10 PM   #1
laynrockers
laynrockers's Avatar
Full porterbuilt 66 with LY5.. Need info on changing oil pan !!
have 07 LY5 + 4l60e going in my 66. I have not changed a pan on these engines before. I am assuming my pan will not fit as this motor is from an 07 Tahoe and is the truck application.
Do I need a new pick up?
New gasket?
Which pan fits with a truck that lays frame?
If there is anything i am missing please let me know and thanks again. Love this forum
Kris
laynrockers is offline   Reply With Quote
Old 08-18-2012, 08:33 PM   #2
paul66c10
paul66c10's Avatar
Re: Full porterbuilt 66 with LY5.. Need info on changing oil pan !!
i believe you would need a camaro oil pan, pick up and screen. Thats what im using on my lm7 5.3 swap in my 1986gmc with a dropmember.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 08-18-2012, 10:24 PM   #3
scotts62
One day...
scotts62's Avatar
I got my 5.3 in today and the pan is ok and laying as low as you but i raised the engine and dont have a dropmember either.
Scott
93 crew cab build
Project 62
Old 08-19-2012, 11:46 PM   #4
jtp67-72
jtp67-72's Avatar
Here's the best buy out there with all the pieces u need....just ordered my 2nd one.....jim
http://www.ebay.com/itm/261032399132...84.m1423.l2649
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 08-20-2012, 08:24 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
wow...that seems spendy!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-20-2012, 10:52 PM   #6
ls1nova71
ls1nova71's Avatar
Judging from that first pic, you're going to need a 4th Gen Camaro pan, all others will hang below the crossmember a bit, unless you raise the engine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-20-2012, 11:11 PM   #7
jtp67-72
jtp67-72's Avatar
that's what in the link above......
Old 08-20-2012, 11:16 PM   #8
ls1nova71
ls1nova71's Avatar
Guess I should have opened the link! But anyway, that was just my opinion.
Old 08-20-2012, 11:37 PM   #9
jtp67-72
jtp67-72's Avatar
And your right!! and with used pans bringing 150-175 bare....I think U can't beat these guys.....ls parts ain't cheap.....yet........jim
Old 08-21-2012, 10:01 AM   #10
LEEVON
Moderator
LEEVON's Avatar
Don't cheap out like me and buy a used f-body pan for $100, then discover a crack, then take it to the shop to be welded, then get a call from the shop demanding $250, then tell the shop to go somewhere and do something intimate to themselves, then settling on $150 for said 5 minute repair, then having $250 into a used, welded oil pan.
Total investment:
-trip to guy's house, dig through his shed, almost get stung. 1 hour + $100
-degreasing, scraping, discovering crack, wife yells at you for making a mess. 1 hour.
-trip to the shop, drop-off pan. 30 minutes.
-another trip to the shop, pick-up pan and engage in not so friendly discussion. 30 minutes +$150
-dress-up repairs because they suck. 30 minutes.
-being pissed off, bad for my blood pressure.
-not sure if repair is going to hold.
So that's 3.5 hours away from my family on saturday morning for $50. Being cheap ain't easy!
GET THE NEW PAN KIT.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-21-2012, 10:03 AM   #11
laynrockers
Thanks-- I will add it to the list
Old 08-21-2012, 05:39 PM   #12
jtp67-72
jtp67-72's Avatar
Total investment:
Man , I could not have written a better excuse for buying a new one!!.....lol......been down that road before....My favorite saying.....Get older get smarter!!.....lol....and more money....jim
Old 10-03-2012, 06:11 PM   #13
laynrockers
Jim,
I just received my pan. Is the install straight forward as i think, anything i would need to know having this be my first time? Did you use a sealant around the gasket ? if so what type?
Thanks for the help
Kris
Old 10-03-2012, 06:38 PM   #14
JNJchev77
Registered Cruiser
JNJchev77's Avatar
A few of the LS swap/rebuild books recommend a bead of sealant/silicone where the pan meets the block and the front and rear covers. I did this, as did many others I've talked to.
And make sure you lube the pick up tube o-ring when installing into the oil pump. Other than that pretty straightforward.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 10-04-2012, 01:00 AM   #15
jtp67-72
jtp67-72's Avatar
And make sure u "square it" at rear .....pan becomes part of the bellhousing mounting pattern...Google "installing Ls oil pan" and use their recommendations .....housing can crack if pan not aligned with block at rear......jim
Old 10-04-2012, 05:03 PM   #16
JNJchev77
Registered Cruiser
JNJchev77's Avatar
^ yes, forgot that. Very important!
77' Chevy SB
5.3/4l60e combo
Old 10-04-2012, 06:03 PM   #17
laynrockers
Thanks fellas, is this the article you were referring too?
http://www.hotrodlane.cc/New%20LS%20...eplacement.htmhttp://www.hotrodlane.cc/New%20LS%20...eplacement.htm
Old 10-04-2012, 09:06 PM   #18
jtp67-72
jtp67-72's Avatar
Originally Posted by laynrockers View Post
That one will work..notice the RED lettering about the pan alignment..critical but fairly easy...jim
Old 10-07-2012, 02:19 PM   #19
laynrockers
Guys ran into a problem on the install. See the pics.. the oil pickup does not fit with the tray. Did you guys get a new tray, cut or hammer this one to work, or just do away with it??
Kris
Old 10-08-2012, 10:36 PM   #20
jtp67-72
jtp67-72's Avatar
Kris
Mine came with pump AND camaro windage tray .....is that stock tray??
Old 10-15-2012, 01:09 PM   #21
66C06
66C06's Avatar
If you have the LS1 pan you need the ls1 windage tray and pickup tube. The LS1 pickup tube is a lower profile tube and will not fit with the truck style windage tray
66C06 is offline   Reply With Quote
Old 10-18-2012, 11:05 PM   #22
laynrockers
Sorry for being the NOOB..
But I cant find the answer so hopefully this thread can be helpful to some in the future + me.
Got the ls1 windage tray. But it is shorter than the stock tray. and does not cover the entire crank area (see pic) do place it toward the front or rear of engine?
Old 10-19-2012, 04:50 PM   #23
jtp67-72
jtp67-72's Avatar
It's been a while since I installed mine but doesn't the pump pickup tube determine the placement of the tray?? Seems like that's what I found....sorry for the cobwebs!!!......jim
Wait I found it....study the pics here..........
http://www.streetrodderweb.com/tech/.../photo_13.html
Old 10-19-2012, 09:01 PM   #24
66C06
66C06's Avatar
it's installed correctly....it should be labled front/rear and it goes in the bolts closest to the flexplate like you have it. Good luck on the rest of your build! I can't wait to start mine...wet-sump ls7...
Old 10-19-2012, 10:46 PM   #25
laynrockers
Thanks guys. Getting antsy gonna be dropping her in tomorrow. Appreciate the feedback.
