Grease upper balljoint on 4x4
guys I need some help please.
I have tried every thinkable position of te wheel and axle, but cant reach this grease fitting. I have tried regular connection and needle... how do you guys grease these babys? ![]()
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
Re: Grease upper balljoint on 4x4
I am not sure what you've got but check out this website, it says factory ball joints don't have grease fittings.
http://www.chuckschevytruckpages.com/lubepoints.html Posted via Mobile Device Posted via Mobile Device |
Moderator
![]() Join Date: Oct 2008
The installer should've used a 90° Zerk.
The only thing I can think of in your situation is a low profile slotted 90° grease gun fitting like this one ![]()
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Real Projects never die
That was a master pro joint. Lol moogs offset so that you can grease them with axle in place.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
could you get something like this in there?
#6 | |
![]() that is why he sold me a neeld adapter: ![]() but so far I have moved the car a hundred times, but not been able to get the right angle to grease the fittings... hope somebody can shine some light on this based on personal experience...
You should be able to remove that zerk and install a 90 degree one in its place. Then, as long as you have it positioned correctly, you will be able to get a grease gun onto it.
x2
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 Last edited by bilfman; 03-24-2013 at 11:04 AM. Reason: . |
Guys,
got any pictures of these 90 degree angle zerk fittings in place? I am asking this, because in my case it seems there would just not be nough room in there for such a fitting.
#10 | ||
Apparently the thinking was that you would need to service the axle joints again by the time you needed to add grease to the ball-joints? Before Spicer came up with the geaseable axle joints, they were un-serviceable too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#11 | |
78K & 79C Jimmys
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Moderator
![]() Try one of these with the U-Joint turned to the right position... ![]()
#13 | |
Those require a specific fitting, not the typical zerk.
Moderator
I've used one on straight zerks that were difficult to reach at best. Dirty grease squirted out around the unsealed shaft away from the zerk so it was feeding through and not just making a mess at the zerk. It wasn't a super tight seal though.
I'd be interested to see the fitting they were actually made for. If it's low enough profile it might be worth changing to... in places like the upper Ball Joint on the Dana44 and down those nasty holes on the baler and the chopper... If I can reach em to swap em out.
#15 | |
#16 |
another reason to not buy master pro
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#17 |
okay, today I tried this fitting. got it from Amazon for great deal.
![]() I thin I had it hooked up, but still no grease went into the zerk fitting I think. man, this greae point is giving me a head-ache. any 4x4 brothers here that succeeded?
#18 |
anybody know the thread of these fittings?
I want to remove the straight fitting and use a 90 degree fitting to grease it and when I am done plug it with a blind fitting. what is the thread size? what are the blind fittings called? any special name?
#19 |
guys!
suc6! so happy.....tried the Thexton grease coupler again today and I guess I never had it put on correctly before. I used a plier to put it on and then connected the grease gun...et voila! suc6...upper balljoints are greased now. just wanted to give heads up over here on my succes. this is the link to the tool: Thexton THE418 Grease Coupler ![]()
