Old 07-08-2009, 09:40 AM   #1
Don Brace
Active Member
WTB three speed cross member
Looking for a three speed cross member. Is this the same as the auto cross member? Would like to see a picture of the three speed cross member so I know what I am looking for.
Don Brace MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 07-08-2009, 09:50 AM   #2
Southern C10
Is it done yet?
Southern C10's Avatar
Re: WTB three speed cross member
Don Brace MN
Don,
From what I know the Auto trans is the only trans that needs a cross member. The Manual trans dosent. I may be wrong.
Hope that helps.
Brian.
1972 Chevy SWB
New 383 Stroker/350 Turbo
Some day i'll paint it
John 3:16
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=398108
Southern C10 is offline   Reply With Quote
Old 07-08-2009, 10:02 AM   #3
Livrat
Member #1049
Livrat's Avatar
Don,
The picture in Prathbun's post is a good representation of what you are looking for..
The manual trans mount is technically a crossmember that is riveted to the frame.
One thing you need to look out for is Chevrolet used two different versions, (not sure about GMC's) a 6 cylinder one and a V8 one,, they look almost identical unless side by side.. the V8 one sits farther forward than the 6 cylinder one..
Sorry I can not help with any pics..
Livrat is offline   Reply With Quote
Old 07-08-2009, 10:22 AM   #4
Don Brace
Active Member
Livrat
Thanks for the information. I am going to the IOLA Wi swap meet today and will look for one. Looks like the one in Prathbun's photo mounts under the bell housing. Is there one that goes under the trans mission?
Don Brace MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 07-08-2009, 10:27 AM   #5
byrd
Union Electrician
byrd's Avatar
Livrat
Don Brace MN
I have two here camne get a pic later, but $10 plus shipping for eithr one, I am not sure if they are 6 or 8 as stated above. I do know they are for a standard tranny. SHipping would be 20 or less I would guess...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-08-2009, 11:14 AM   #6
Don Brace
Active Member
Randy
Are the two you have the same or are they different from one another?
I am off to IOLA WI car swap meet and will get back to you on Saturday. My guess is the only difference between the six and eight cross member is the mounting holes which is no big deal. I looked under my truck and there are two sets of holes to mount the cross member.
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 07-08-2009, 11:24 AM   #7
HuggerCST
HuggerCST's Avatar
No, not with standard transmissions. Automatics only.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 07-08-2009, 11:44 AM   #8
Southern C10
Is it done yet?
I learn something new here everyday!!
1972 Chevy SWB
John 3:16
MY BUILD THREAD
Old 07-08-2009, 11:46 AM   #9
byrd
Union Electrician
byrd's Avatar
Yep I am purty sure not under the tranny, just the bell housing
Zip:40272
Old 07-08-2009, 12:31 PM   #10
Don Brace
Active Member
Currently I have an automatic crosss member under my 3 speed overdrive and none under the bell housing. I have lots of clutch chatter and think that not having the member under the bell housing maybe part of the problem.
Thanks for the replies.
Don MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 07-08-2009, 11:30 PM   #11
byrd
Union Electrician
byrd's Avatar
pics of manual x-member
Zip:40272
Old 07-09-2009, 12:38 AM   #12
Livrat
Member #1049
Livrat's Avatar
Don..
from the factory all the trucks used one under the belhousing..
GM cars used one under the trans, if you have the surface on the tailshaft of your trans for a mount you can use the stock truck automatic crossmember.
Livrat
Don Brace MN
Old 07-09-2009, 12:43 AM   #13
Livrat
Member #1049
Livrat's Avatar
oops, replied to your original post before I saw this one..
If you have alot of clutch chatter it is more than likely for some other reason than the rear mounted crossmember... probably either a warped flywheel, bad clutch disc.. pilot bearing worn out.. bad input bearing in the trans etc..
Don MN
Old 07-11-2009, 05:42 PM   #14
Don Brace
Active Member
I'll check on the clutch and the pilot bearing and let you know.
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 07-11-2009, 06:38 PM   #15
too much stuff
Roadtrip!
too much stuff's Avatar
Don, did you find your parts at iola? If not, i will see if i have something here on a parts truck if you still need it. Eric
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-12-2009, 08:18 AM   #16
Don Brace
Active Member
Eric
I am still looking for the three speed cross member and the inner passenger side rear bumper bracket. Also trying to figure out why my power steering pump is so close to the alternator bracket that I cannot get the P/S cap off.
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
