Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-13-2009, 01:39 PM   #11
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Here's some pics. of what I'm into...
Alum. fuel line. Found out that -6 and -8 AN sizes are uni-flare, meaning a 45° flare tool will work. After seeing what happened to AJ's engine, I left a piece of rubber fuel line after the fuel filter that can be clamped off to run the engine out of fuel and work on the carb. Still waiting on the last of the fittings after the fuel filter, it is a 150° bend so the rubber hose doesn't hit the cross member
After alot of help, including diagrams, from the electrical guys( thanks VetteVet) I decided to send the harnesses back to M&H for the mods. Still under warranty, should be back in a couple weeks. Got the mechanical side of the water pump plumbed, so that is a plus
Interior is still pending, samples arrived, exactly as original. But they included a green color, and that threw a monkey wrench in the works
Clocked my alternator, another problem, since the armature came outta the brushes. Realized there is a hole thru the brush holder and rear half of housing to insert a rod to retain the brushes and allow you to reassemble the armature. DO NOT separate the field windings and rear half of the alternator, bad things will happen! You only have to pivot the front half to get the wire locations correct
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
