Old 12-11-2009, 01:27 PM   #1
JOEGMC
JOEGMC's Avatar
np 205
Guys my uncle has a 205 transfer case he says i can have for my build, the question is how do i know if it will work with sm465 Tranny ?
1977 GMC Camper Special
JOEGMC is offline   Reply With Quote
Old 12-11-2009, 02:01 PM   #2
Thealien
Thealien's Avatar
Re: np 205
What was the NP205 out of? What transmission was it hooked to? Divorced or?
You can usually make it work but you might have to change an input shaft or? Does it come with the adapter? You will need one.
Old 12-11-2009, 02:48 PM   #3
JOEGMC
JOEGMC's Avatar
Re: np 205
I'm not sure what its out of, someone gave it to my uncle. It is in his shed somewhere i just haven't had a chance to go get it. I not sure if the adapter is on it or not i hope it is if not i just have to buy one. I'm just wondering which input shaft i need for my granny four. I just think i would rather have the 205 then the 208 i have now. Thanks for the help!
Old 12-11-2009, 04:19 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
Re: np 205
correct me if i'm wrong guys, but isn't a 208 basically just an aluminum 205?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 12-11-2009, 04:32 PM   #5
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: np 205
I believe for a 4 spd 205, you need the 10 spline Chevy version.
As for the 208, yeah I think it is a pert time case like the 205, obviously not as stout.
I saw a couple of threads here about them, and have found these links online. I am sure there is a ton more...
http://www.offroaders.com/tech/Diagrams/np205.htm
http://www.offroaddesign.com/catalog...rcaseparts.htm
http://www.tbtrans.com/transfer_case.htm
http://www.jbconversions.com/index2.php?pc=3
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 12-11-2009, 05:30 PM   #6
Damien
Damien's Avatar
Re: np 205
The NP208 is an aluminum case and chain drive. The NP205 is an iron case and gear driven.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-12-2009, 01:40 AM   #7
2tons of fun
Re: np 205
no.
so incredibly no.
unbelivably no.
if some one heard you say that in person you would be in serious danger no.
you never said what year 465 either,
older will need a 10spl male.
newer will need a long 32spl female.
2tons of fun is offline   Reply With Quote
Old 12-12-2009, 10:24 AM   #8
68 TT
Still plays with trucks
68 TT's Avatar
Re: np 205
Is this in your 77 from the sig or another truck?
The 205 your dad has could be 10, 27 or 32 spline if it is GM and different than that if it is Dodge.
Your 77 should be 10-spline.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 12-12-2009, 11:16 PM   #9
JOEGMC
JOEGMC's Avatar
Re: np 205
Well guys here's what i got. My 77 is 2wd I am redoing a frame from a 83 that had a sm465 with a 208 transfer case to do a frame swap. Im getting this 205 for free and would like to use it in my build. Thanks for all the help everyone.
Old 12-13-2009, 12:20 AM   #10
oats84
oats84's Avatar
Re: np 205
I have had both of those t-cases deppending what your use for the truck is. I run a 241 in my truck and love it because of the low range being a 2.72.1 and the 205 is like 1.96.1 if i remeber right.
1989 jimmy "U.A.V"
44/14blt 4.56s locked up
37's
1984 2wd swb
1969 swb 4x4
oats84 is offline   Reply With Quote
Old 12-13-2009, 05:30 AM   #11
2tons of fun
Re: np 205
that 465 is going to have the 32 spl out put and you will need the 32 spl long female input shaft and it will need to have the circle 6 bolt pattern.
Old 12-13-2009, 04:29 PM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: np 205
Yea that sounds right. If you can make it work go ahead and use the 205. While its out already I would take the time to clean it up change the fluid and put new seals in.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 12-13-2009, 06:50 PM   #13
JOEGMC
JOEGMC's Avatar
Re: np 205
I would like to use it. For the strength. If i have to ill use the 208, but I would rather use the 205. I figure if im gonna clean one up and put new seals in it. I might as well use the 205. Im Building the truck to use it, to haul coal and firewood.
Old 12-13-2009, 07:53 PM   #14
oats84
oats84's Avatar
Re: np 205
Don't forget that the driveshafts will prob differ between the two
1989 jimmy "U.A.V"
37's
1984 2wd swb
1969 swb 4x4
