Old 04-04-2010, 11:54 PM   #26
djw32
Re: my daily driven '68 LWB 5.3/4l60e
What a great truck!
What motor mounts did you use?
djw32 is offline   Reply With Quote
Old 04-04-2010, 11:57 PM   #27
speed-racer
speed-racer's Avatar
Originally Posted by djw32 View Post
What a great truck!
I used Early Classic and they worked out great.....no problems.
speed-racer is offline   Reply With Quote
Old 04-05-2010, 12:02 AM   #28
LEEVON
Moderator
LEEVON's Avatar
Nice truck. I ran one of those seats for years, they make them completely different trucks and comfortable to drive.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-05-2010, 12:03 AM   #29
speed-racer
Had to post my favorite picture of the '68......none of the modern junk in the background of this one.
Old 04-05-2010, 12:06 AM   #30
Hart_Rod
Hart_Rod's Avatar
Sweet picture! What gear do you have in the rear? What kind of mileage are you getting?
Hart_Rod is offline   Reply With Quote
Old 04-05-2010, 12:17 AM   #31
speed-racer
Well, I ran 3.73 gears up until 3 weeks ago. Now I've got a '70 rear end with 3.08s. Something in between would be perfect. I get 16 mpg driving 65 mph and under and drops like a rock after 70. Ive never gotten less than 13 mpg. The 3.08 gears are just too high to drive on the interstate at 70 mph unless its a fairly flat grade. I really liked my 3.73s better, but the '70 rear end was the right width to match the front disc brakes and easily keep everything 6 lug (I have 6 lug rotors up front).
Old 04-08-2010, 11:34 AM   #32
jht3rd
I am wondering how and what you used to put a connection in the bottom of the gas tank,and does it leak? I'm thinking of doing this swap and would like to keep the stock tank as well. By the way I cant see your pics any more.
maybe something wrong on my end though.
jht3rd is offline   Reply With Quote
Old 04-11-2010, 12:45 AM   #33
speed-racer
I used a bulkhead fitting and o-rings. Very similar to this one.....
Be sure to drill a nice clean hole and use the proper o-rings. I had trouble out of mine after a year because the o-rings I used were not supposed to be used with fuel. After using the right o-rings I've had no problems. Its been two years since I made the repair. If it happens again I'm going to epoxy the bulkhead fitting to the tank. I used the factory fuel supply line on the top of the tank as a return line.
Old 04-11-2010, 04:24 AM   #34
CheyenneShop
CheyenneShop's Avatar
I like your style!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 04-11-2010, 11:05 AM   #35
martindc1
Your truck is sweet, I'm digging your style as well. Since you did this swap, changing a gear set should be no problem for you. Other than that, I wouldn't change a thing on your truck. I like the stance, wheels and everything. Though I'm partial to the stock style black vinyl seats. My K20 isn't much more optioned than yours. I for one prefer it that way.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 04-11-2010, 11:45 AM   #36
speed-racer
I like the factory seats appearance, but you can't beat the comfort of this one. And I've got a fold down armrest! This seat actually came out of the back of a crew cab dually and has no headrests which is the only reason I was up for installing it over the factory seat.
Old 04-11-2010, 11:53 AM   #37
martindc1
The seat in my 67 is from a 72 Cheyenne Super, and it is really springy, which helps with the rough ride. My 72 has a seat out of an early 90s 1500 w/t, and it works out pretty well. I dig what you're saying though.
