Old 05-04-2010, 08:12 PM   #1
jyaughn
jyaughn's Avatar
door
got my new rocker put on but found out that when i welded in my patch panel for the lower part of the door i warped the front corner. does anyone know how to fix this?
jyaughn is offline   Reply With Quote
Old 05-04-2010, 08:57 PM   #2
shortbed70
shortbed70's Avatar
Re: door
You could probably hamer and dolly it back out.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-04-2010, 09:00 PM   #3
jyaughn
jyaughn's Avatar
Re: door
the hole corner is pulled in too far and the bottom of the door doesnt sit flush with the rocker
Old 05-04-2010, 11:12 PM   #4
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Re: door
Got a pic?
You may have put a cut in the door, get if where you want, and reweld it. Do it on the truck if possible to make sure the door fits with the rocker and door opening
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 05-04-2010, 11:18 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: door
Originally Posted by tapeworm View Post
Got a pic?
also check that the rocker is not the problem, and be sure to mount the fender as well to get all three pieces lined up.
Old 05-05-2010, 07:38 AM   #6
jyaughn
jyaughn's Avatar
Re: door
it lines up good. so i have to cut my new panel off the door to try and straightin it back out
Old 05-05-2010, 07:40 AM   #7
jyaughn
jyaughn's Avatar
Re: door
i cant really mount the fender right now cause my truck is just a cab and a frame. its all takin apart with all the rusted stuff thrown away. so i have no core sopport right now
