Old 05-04-2010, 10:50 PM   #26
chev-obsession
chev-obsession's Avatar
Re: want to cut springs have ???'s
Originally Posted by oldblue1968chevy View Post
tried napa and they cant get it reasonably ($65) and orielly autozone etc autmatically says 'no'
I'd say around $50-$65 is reasonable. I had to get stock ones made at a shop locally. The receipt is gone now, but it was just a dollar or two shy of $60. It would probably be cheaper to do that than to get the nuts washers and bolts through lmc.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 05-04-2010, 10:53 PM   #27
Leviticus
Shake and Bake!
Leviticus's Avatar
I'd check to see if you have a Big Rig shop near you, I had a Big Rig alignment/spring shop make mine for $20.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 05-04-2010, 10:57 PM   #28
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
we got some kinda shop locally (bfe) but they wanted 60+ lol
John
1999 Toyota Tacoma 4x4
Old 05-04-2010, 10:59 PM   #29
Leviticus
Shake and Bake!
Leviticus's Avatar
Yeah, that's a little steep. Hopefully you can find a cheaper set.
Thomas Jefferson
Old 05-04-2010, 11:17 PM   #30
chev-obsession
yeah i know its expensive but around here its considered reasonable being since thats the only place that could make them/have them. btw it was a driveline shop. everyone else recomended them.
1965 c/10 swb
1969 c/10 lwb
Old 05-05-2010, 01:38 AM   #31
psuautotechstudent
psuautotechstudent's Avatar
I ordered lowering springs online and cut a coil out of them. Thought the original ride was rough... I hate hitting bumps in my truck now. Really not worth it in my opinion. Your sacrificing alot of ride quality for a few inches lower. I mean it looks good, but like I said, every little bump gives me a headache
1968 C10 250 I6
psuautotechstudent is offline   Reply With Quote
Old 05-05-2010, 09:28 AM   #32
oldblue1968chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=356615
check out the jeep wrangler thead I made it come back to life, may check into this, but id like some more info on how strong they are (can i still haul stuff in bed)
John
Old 05-12-2010, 12:04 PM   #33
Renfro85
i checked out the thread but never saw anything about what year wrangler springs i needed
Renfro85 is offline   Reply With Quote
Old 05-12-2010, 12:16 PM   #34
mr48chev
mr48chev's Avatar
The Wrangler springs look like the deal if you don't plan on hauling much of a load which most guys with custom trucks don't anyhow.
Old 05-12-2010, 12:31 PM   #35
leddzepp
Moderator
leddzepp's Avatar
I just got some Wrangler TJ springs off craigslist. Any year from 97-up. YJ Wranglers used leaf springs and were from 87-95. There was no Wrangler model in 96. After putting them in, they only lowered my truck by 1/4". Of course, there is no bed on my project at this time, so I can only assume the weight of the bed will compress them down. They are IDENTICAL in height to my factory springs, so it has to be the weight rating that is different. The coils are about half the diameter of the originals. I doubt you could haul much in the bed with them, other than a cooler full of beer (which is all I ever plan on hauling anyways).
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-12-2010, 01:23 PM   #36
hdzammo
hdzammo's Avatar
bought my jeep springs off craigs for $20, and cut one full coil from the front springs. it brought me down about 2" up front and about 3.5" in the back. you will not be able to haul anything heavy like a boat or u-haul trailer, but the ride is still very good.
hdzammo is offline   Reply With Quote
Old 05-12-2010, 01:34 PM   #37
hdzammo
hdzammo's Avatar
here is how it looks now
Old 05-12-2010, 06:05 PM   #38
junkyardjohn
junkyardjohn's Avatar
THE REAR COILS OFF OF A LATE 70s EL-CAMINO BOLT UP, & GIVE YOU 3 OR 4" OF DROP. NO PROBLEM CUTTING ONE COIL OFF THE FRONT. JUST MAKE SURE TO USE A CUTOFF WHEEL & DON'T GET EM HOT. FOR GODS SAKE.... DON'T CUT THE REAR COILS NO MATTER WHO SAYS IT'S O-K. IT'S NOT. & DON'T TAKE A TORCH TO EM EITHER. IF YOU WANT TO KILL YOURSELF... H@LL ... I WONT GET IN YOUR WAY, BUT THE PUBLIC ROADS ARE JUST FULL OF INNOCENT PEOPLE THAT MAY NOT WANT TO GO WITH YOU. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-12-2010, 06:13 PM   #39
junkyardjohn
Originally Posted by Hubscrub View Post
no problem no harm taken i want the truck to be as safe as possible for my wife and i because you can buy replacement truck parts but you can't buy a replacement for her or her body
YEP.. CAN'T BUY EM.. BUT YOU CAN RENT EM. JOHN (JUST A FEEBLE ATTEMPT AT HUMOR...... LIGHTEN UP)
junkyardjohn
DON'T RENT U-HAUL
Old 05-12-2010, 06:21 PM   #40
1LoC10
Insert Title Here
1LoC10's Avatar
8- 50lb bags of sand dropped my rear nicely
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-12-2010, 06:25 PM   #41
leddzepp
Moderator
leddzepp's Avatar
Cinder blocks work well too, and the added weight makes for a better ride.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-13-2010, 12:17 AM   #42
Renfro85
I started the process of installing the wrangler springs tonight, I just don't know if my shocks are goin to bottom out or not.. anyone had any issues with that, and if so maybe a hint at what size shockes I need to run
