Old 07-08-2010, 07:30 AM   #1
69c10step
69c10step's Avatar
Re: Lifting engine
When I changed mine (IIRC), I just unbolted the motor mounts, used a floor jack to raise the engine up a couple of inches and then slid a 2x4 block in between the mounts and the motor. Worked well - just another way of doing it I guess.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 07-08-2010, 02:08 PM   #2
1968CHEVYC10
1968CHEVYC10's Avatar
Re: Lifting engine
Did you have to mess with the rad hoses? I just changed my coolant and don't really feel like changin it again.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 07-08-2010, 02:12 PM   #3
69c10step
69c10step's Avatar
Re: Lifting engine
I don't think that I did (it was about 3 years ago). I didn't have a ton of room to work with, but enough to wiggle the pan off.
Old 07-09-2010, 03:18 AM   #4
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
Re: Lifting engine
exactly!
I had a friend jack up both the oil pan and transmission pan at the same time (with 2x4s between jack and pans) then slide pieces of 2x4 in motor mount spot . He had to loosen tranny mount bolts and of course motor mounts. Hoses won't be disturbed with the 2-3' inches of lift.
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 07-09-2010, 09:57 AM   #5
mrein3
mrein3's Avatar
Re: Lifting engine
Originally Posted by beebster View Post
exactly!
I think this is what the GM service manual recommends. And is how I've done these jobs.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
