Old 07-08-2010, 02:08 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Re: Lifting engine
Originally Posted by 69c10step View Post
When I changed mine (IIRC), I just unbolted the motor mounts, used a floor jack to raise the engine up a couple of inches and then slid a 2x4 block in between the mounts and the motor. Worked well - just another way of doing it I guess.
Did you have to mess with the rad hoses? I just changed my coolant and don't really feel like changin it again.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 07-08-2010, 02:12 PM   #2
69c10step
69c10step's Avatar
Re: Lifting engine
I don't think that I did (it was about 3 years ago). I didn't have a ton of room to work with, but enough to wiggle the pan off.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
