Re: QJet Adjustments
My first question is, Do you see alot of black smoke when you mash on it? The Quadrajet is vacuum operated so it should not be dumping gasoline unless you have enough vacuum to open the secondaries. Is your carb the original one on your truck?
#2 | ||
The carb is the original one to the truck that I know of. I pulled this engine and carb out of a K20 that was all rusted, and put it in my k10.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
When your truck is warmed up, remove the air cleaner and operate the throttle to simulate condition you describe above. On two of my squares, the Qjets had a sticky choke valve, causing the engine to bog and consume a lot of gas. These choke valves and associated linkage have a tendency to carbon up and stick. I had an Edelbrock that had a choke valve that was manufactured slightly too big for the opening in the carb - I had to remove the valve and file it off slightly - then the choke would never close off completely and caused hard cold starts.
#4 | |
When those secondaries open it pulls some needles out of the big secondary jets that dump fuel down your carburator. I have to warn you that this is my theory, I am not an expert and there is most likely 100's of people here who are experts. |
#5 | |
#6 | |
