#26 |
Re: Front rally wheel clearence issue, need help..
So I would be completely fine with those ralleys? As far as fitment goes?
#27 |
67-72 parts collector,…
![]() Join Date: Nov 2002
The wheels in the pic from the Craigslist ad look like 15x7's on the left and 15x6.5's on the right.
I would try to find a set of 15x8's for the rear. 15x6.5 (4" BS) 15x7 (3-5/8" BS) 15x8 (4" BS) What is the backspace of your wheels?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-10-2011 at 08:55 AM. |
#28 |
Honestly, I dont even know of the backspacing on them. Never even checked if its nice out this weekend I will pull one off and find out.
#29 |
Have you done any trimming on the lower a-arms?
With minor trimming any 4" backspaced 15" wheel will work with 2.5" or 3" drop spindles. I suspect your 88-98 wheels have more than 4" of backspacing.
#30 | |
I was looking at it last night and was almost thinking a small 6-7 mm spacer would be enough. That would still even give me enough hub so the truck wouldnt be "held" up by the wheel studs. |
#31 |
I recall the 88-98 steelies having 4.25"bs but don't have one handy for verification. We installed 73-87 ralleys on my old buddies 91 for this reason. We did 6.5" vans up front & 8" trucks on the rear. Slight clean-up of the lower a-arm & we were good to go.
#32 |
I will tear into is this weekend and figure something out. Might just end up getting the truck ralleys.
#33 |
not quite sure what the b.s. is on mine but they did not rub on my lca's after I switched wheels.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 Last edited by mooseknuckles; 02-10-2011 at 07:11 PM. |
#34 |
Those are the 'styled' wheels & do not share the same back-spacing as the steelies from what I remember (it's been a few years since I played w/late model 88-98 stuff).
#35 |
this wheel here has the least back spacing of the 7's I have ,its 3 1/2" ,they look like the yours and came from a 92 chevy ,they had the most clearence on my truck ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
| Bookmarks |
