Old 08-29-2011, 02:13 PM   #301
65Gregg
65Gregg's Avatar
Re: No Limit '72 C-10
Rob when are you guys going to install the rear bags on Project JT, you have convinced me that your rear shock relocator is the way I need to go along with 3 inch springs, however I like you want the option to carry a load or pull a trailer so there is no reason to put springs on then replace those with bags.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 08-29-2011, 04:12 PM   #302
djw32
Originally Posted by robnolimit View Post
Yes a manual would be better for performance, but this is going to be drivin in So. Cal. traffic. It has 3.73 gears (stock) and a 275/40/18 tire all around, so we can rotate. In June, we will be driving up to Pleasanton with a group from Pro-Touring.com, some on hwy 1, and some on 99, with a trans controller/programmer - looking at the Bully-Dog, we hope to get 24+ on the long sections, but that means no screwin' around, at least on the mileage test
The truck looks great!
What backspacing did you go with? Those rims look really good on the truck.
djw32 is offline   Reply With Quote
Old 08-31-2011, 06:44 PM   #303
Greywolf200
Hi Rob, Did you ever get a chance to check out the extended upper ball joints to get some camber gain? If I missed it, I apologize.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 09-02-2011, 01:00 PM   #304
robnolimit
robnolimit's Avatar
No problem. I've used them on others, but not yet on the JT. So far, we have the used upper arms on it. But, I can say with confidence that there is a gain hear, for cheap. If you need to replace yours, get the tall truck ball joints from Howe or the likes. You'll be glad you did. This weekend is the Great Labor Day Cruise in OC, we will be autocrossing there. Log in to our facebook for pict & video updates. Have a great weekend.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 09-12-2011, 07:19 PM   #305
robnolimit
robnolimit's Avatar
Our new C-10 front bar mount directly to the frame rail. If equipped, the factory standoff must go. the rivit connecting the frame rail to the front crossmember is removed, and then a 3/8" hole is drilled 3" behind on the rail.
Old 09-12-2011, 07:20 PM   #306
robnolimit
robnolimit's Avatar
This is the front bolt-through the rivit hole. the bar is big 1 3/8" dia.
Old 09-12-2011, 07:23 PM   #307
robnolimit
robnolimit's Avatar
With ridetech a-arms the sway bar link connects to the tab provided. the link is appx 9" long, long enough to get the bar up above stock style steering.
Old 09-12-2011, 07:24 PM   #308
robnolimit
robnolimit's Avatar
On a stock arm, you need to drill a 3/8" hole int he arm. This is an old tet pict-hence the nifty all thread.
Old 09-12-2011, 07:25 PM   #309
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Did you happen to get any exhaust routing shots while you had it on the lift.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 09-13-2011, 11:31 AM   #310
aggie91
I'm just glad to be here!
aggie91's Avatar
I saw the article in Street Trucks about the suspension mods. Can you elaborate more on what you did for the front crossmember and for the mods to the rear frame? Pictures would be nice...
Thanks,
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-14-2011, 08:10 PM   #311
robnolimit
robnolimit's Avatar
Here is the J.T. going to powder coat with a chassis in the back.
Old 09-15-2011, 03:26 AM   #312
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Now a cool longbed would have swallowed the majority of that frame.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 09-16-2011, 11:46 AM   #313
robnolimit
robnolimit's Avatar
next time it's on the rack I'll get some shots.
Old 09-16-2011, 11:47 AM   #314
robnolimit
robnolimit's Avatar
Thanks,
check the 'make it handle thread later today.
Old 09-16-2011, 11:55 AM   #315
PBFAB.COM
PBFAB.COM's Avatar
This pic makes me smile every time I see it.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-16-2011, 11:57 AM   #316
smbrouss70
smbrouss70's Avatar
What is that chassis going under? It looks awfully tall.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-25-2011, 06:11 PM   #317
BustedTruck
BustedTruck's Avatar
I didn't see it anywhere, but I am curious I want to set my 5.3 back further. Did you make your own engine stands or where can I purchase them?
BustedTruck is offline   Reply With Quote
Old 10-13-2011, 03:21 PM   #318
robnolimit
robnolimit's Avatar
With the crossmember up 1 1/2", it was easier just to make new mounts. The firewall is stock, but we set the motor back as far as we could.
Old 10-13-2011, 08:41 PM   #319
a.c.ward
Rob,
it was sure nice to get to meet you at the Good Guys Lone Star show in Fort Worth! It was humbling to know that you had some something to do with my El Camino. Thanks so much for signing my magazine, I will treasure it for as long as I can.
Look forward to seeing more of Joe Touring, keep up the awesome support of the board and those of us who live thru your work.
AC Ward
A C Ward Retired US Army
66 El Camino
67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475
a.c.ward is offline   Reply With Quote
Old 10-13-2011, 09:30 PM   #320
robnolimit
robnolimit's Avatar
Originally Posted by a.c.ward View Post
Rob,
AC Ward
It was great to meet you A.C. For those that don't know, A.C. has the Painless Performance El Camino. I know it made a few Hot Rod Power Tours, and it was cool to see it in Texas at the GoodGuys show. A.C. is a true American Hero!! and is now working for the US ARMY on contract in Afganistan. (I hope I got that right) At home, he is working with a christian rod club (sorry A.C. I forgot the name) to help out as he can. It was great to meet you A.C. , I should have had you sign something of mine. Keep the faith. Next time I show up in Texas, I need to give you a rider in the 'Bullit.
Old 10-14-2011, 08:44 AM   #321
a.c.ward
Rob, you got it all right! Great that you remember this old soldier.
For those intrested in the Christian Car Club that I belong to, here is a link:
holyrollerz.org
we are a nation wide club, with multiple chapters in many states, over 6500 members as of 10/15/2011, and growing.
Thanks to Rob and the No Limit crew for remmebering those who have served, and still serve. The honor is all mine to be able to rub elbows with those who make a huge impact in this hobby/business and know that they take the time to talk to us, even thou all weekend, there were many folks lined up to talk to them.
Thanks again Rob, and keep the faith brother.
GODSPEED
66 El Camino
Old 10-14-2011, 02:51 PM   #322
BustedTruck
Thank You for your service A.C.
Rob on the front cross member, I didn't see that in this thread do you have any details or pictures on how this was done?
Old 10-14-2011, 02:54 PM   #323
hotrod1
56 - autocross
hotrod1's Avatar
Hey Rob:
I am interested in using hydroboost unit. I have your front power steering rack (t bird, I think). I will be using a LS motor and what ever pump comes with it. Are there any adapters or anything that I will need to do? Doesn't Ford use lower pressure?
hotrod1 is offline   Reply With Quote
Old 10-15-2011, 08:27 PM   #324
Ackattack
Ackattack's Avatar
we did flip the trailing arm mounts, to raise the anti-squat. The coating is called 'Raptor' liner, and its like a spray on bed liner. It's tough stuff, and easy to use. The cab was pressure washed, and sealed. We had to make raise the trans tunnel, so that was done and sealed up too.
Wow, great build. I love the inovation and developing parts to improve handling.
I really like how you re-located the lower ball joint. I'll have to look into this.
My question is, can you raise the anti-squat too much? Because the anti-squat lines with or without drop blocks would be different correct? So with say 2" drop blocks and flipped trailing arm mounts, is that going to be too much. Is it "more the merrier, or find the happy medium?
Ackattack is offline   Reply With Quote
Old 10-16-2011, 01:51 AM   #325
SCOTI
SCOTI's Avatar
I love it when 'the class' pays attention....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
1972 chevy, c-10, no limit engineering
