Old 12-15-2011, 10:12 AM   #376
nobull2
nobull2's Avatar
Re: The Fuse is Lit...
That dash is sweet.
nobull2 is offline   Reply With Quote
Old 12-15-2011, 08:58 PM   #377
n2billet
Village Idiot....
n2billet's Avatar
Just curious; is your tach nice and smooth or does it jump around? I had a few issues with mine (got it all worked out) just would like to know if any others had any issues.
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 12-16-2011, 12:00 AM   #378
RocketKing
RocketKing's Avatar
To be honest I have not run the engine much due to not having the radiator installed, but what time I have run it the tach has been pretty smooth.
Rex
RocketKing is offline   Reply With Quote
Old 12-16-2011, 12:03 AM   #379
mcbassin
Still Learning
mcbassin's Avatar
Hey Rex, you can use mine for a while if you need.I did a long test run last night with my new radiator hooked up. Amazing how good the test run went once I got rid of all the old gas.
Do you have a plan for your tranny cooling lines? Are you using the OEM quick connect style?
Old 12-16-2011, 12:26 AM   #380
RocketKing
RocketKing's Avatar
Thanks for the offer Mike but the 10 hr round trip might be a little counter productive.
On the tranny I am leaning toward the AN fittings from Sweet Performance and then using braided lines. That is the plan anyway. But, seeing as I spent this evening completely rewiring my dash so I could move my PCM out of the cab to see if it would reach my core support, my plans change alot.
Rex
Old 12-16-2011, 12:46 AM   #381
mcbassin
Still Learning
mcbassin's Avatar
Come on now, you're killing me. I have been planning all along to mount my PCM inside the cab. What's the deal? Does it muck up your a/c-heater install?
My wiring is no where near complete so I have flexibility. I just thought it would help clean up the engine bay if it's in the cab.
I am leaning toward braided stainless too with AN-6 fittings. Not sure yet. I've also thought about inline tube's stainless "oem" prebent lines. I think they will be a pain to install based on my brake line experience.
How about some wiring pics?
Old 12-16-2011, 01:48 AM   #382
RocketKing
RocketKing's Avatar
LOL, I know, I keep changing my mind but the PCM is just so tight between the fuse box and brake booster brace. It can fit there if it has too but it is like stuffing a size 12 foot into a number 10 shoe. I am wanting to see just where it could fit on the core support if I built a nice box for it and dressed it up some.
I would be glad to show some pics but like I said now my wiring is torn apart again.lol
and besides... the last time I showed you wiring pics you got your engine started before me!
Rex
Old 12-25-2011, 12:55 AM   #383
RocketKing
RocketKing's Avatar
Didn't like the PCM outside either so I tried something different back inside the cab.
I modified the brake booster bracket so the wires for the PCM would reach father.
Then I bent some metal for a bracket to hold the PCM.
and attached the bracket.
Then mounted the PCM
Rex
Old 12-25-2011, 10:27 AM   #384
raull
raull's Avatar
thats cool , tucked away but easy acces !!!!!!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 12-25-2011, 03:30 PM   #385
hgs_notes
GEARHEAD
hgs_notes's Avatar
Good idea!
hgs_notes is offline   Reply With Quote
Old 12-25-2011, 05:29 PM   #386
68 Four on the Floor
68 Four on the Floor's Avatar
I like that. Looks good Rex
68 Four on the Floor is offline   Reply With Quote
Old 12-25-2011, 06:03 PM   #387
mcbassin
Still Learning
mcbassin's Avatar
I like what you got going there Rex. I hope you made a few of those brackets
Merry Christmas!
Old 12-25-2011, 09:19 PM   #388
RocketKing
RocketKing's Avatar
Thanks raull, I hope it is easy access, things are getting tight in there! lol
Originally Posted by hgs_notes View Post
Good idea!
Appreciate it!
Merry Christmas!
Thanks Mike, I would be glad to get you one anytime, but with your metal skills you could fab a bracket that would make me want to throw mine away! lol
Rex
Old 02-10-2012, 12:25 AM   #389
RocketKing
RocketKing's Avatar
Need an opinion...
My tranny was hitting the bottom of my cab, so I lowered the rear end of the tranny to allow some room. That of course tilted the motor toward the firewall. Do you think it tilts too far?
The only option I would have is to raise the tranny back up and put 1/4spacers under the cab mounts.
Rex
Old 02-10-2012, 01:19 AM   #390
mcbassin
Still Learning
mcbassin's Avatar
Need an opinion...
Rex,
Not sure about the spacers? Any chance you could shoot some pictures of the bottom side where the interference is? I have had this fear since I have a low hump in my "new" cab. If you use spacers, you'll have to raise all of the other parts too right? fenders, bed?
Your motor looks great! where did you score the headers? maybe I missed it?
Old 02-10-2012, 01:23 AM   #391
Looks like you have tons of room up front. Can you move the entire drivetrain up and inch or so?
Old 02-10-2012, 01:29 AM   #392
RocketKing
RocketKing's Avatar
Rex,
Yes, I would have to use spacer all the way around, just not wanting to go that direction, but I dont want the motor to "tilted" to far back either. Thats why I was asking opinions, to see if looks bad or if it was just me being over sensitive.lol
No you didn't miss the headers I just have been lazy about posting. I got them from Shon, they are the Doug Thorley's
sooo shiny!!
Of course with my home fabbed brackets they sat a little to low
But I "massaged" the frame with a grinder and everything fit.
Honestly that pic makes it look closer than it is actually.
Rex
Old 02-10-2012, 01:33 AM   #393
RocketKing
RocketKing's Avatar
Yes, I could. I would rather eat dirt that move those adapter plates again though.
Actually, I don't think moving forward will help the shallowness between the cab and tranny. But that is a good idea though... I am gonna double check and make sure.
Rex
Old 02-10-2012, 09:36 AM   #394
nobull2
nobull2's Avatar
It does not look that bad to me but I would want to put and angle finder on your drive shaft to see where the u joints are. Could cause a vibration if the trans is to low.
Old 02-10-2012, 10:13 AM   #395
hgs_notes
GEARHEAD
hgs_notes's Avatar
Based on the other LS builds I've seen, tilting it back several degrees seems to be the norm. In fact, yours seems to have less tilt than most.
Old 02-10-2012, 10:38 AM   #396
67cheby
67cheby
67cheby's Avatar
can you just add the high hump ? or is yours a high hump, that would seem like the easiest solution, you can usually pick one up for 50-60
67cheby is offline   Reply With Quote
Old 02-10-2012, 11:18 AM   #397
RocketKing
RocketKing's Avatar
Your right about the drive shaft, but my rearend in only tacked in place so I could move it if necessary.
Thanks, I like the sound of that!
I knew it would be you!!
As I lay on my back, looking up at that tranny last night I thought man a high hump cover would take care of all of this.
The main thing is that I already have my carpet but I guess...
Wait a minute... are you trying to turn my truck into an 8 year build? lol
Rex
Old 02-10-2012, 11:19 AM   #398
67cheby
67cheby
67cheby's Avatar
mmmuuuuuuu hhhaaaaa hhhaaaaaa......evil laugh ! on a side note those headers are just plain SEXY !!
Old 02-10-2012, 05:10 PM   #399
mcbassin
Still Learning
mcbassin's Avatar
Rex,
Those headers are awesome man! I'm sure you will figure out the clearence issue. I would like to take some measurements on mine before I mount the cab on the chassis.
Old 02-11-2012, 01:24 AM   #400
RocketKing
RocketKing's Avatar
They ought to be sexy for what they cost!!!
Rex,
Yes, measure once, cut twice ...
wait thats not right.
Rex
