#376 |
Re: The Fuse is Lit...
That dash is sweet.
#377 |
Village Idiot....
Just curious; is your tach nice and smooth or does it jump around? I had a few issues with mine (got it all worked out) just would like to know if any others had any issues.
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#378 |
To be honest I have not run the engine much due to not having the radiator installed, but what time I have run it the tach has been pretty smooth.
Rex |
#379 | |
Still Learning
![]() Do you have a plan for your tranny cooling lines? Are you using the OEM quick connect style? |
#380 | |
![]() On the tranny I am leaning toward the AN fittings from Sweet Performance and then using braided lines. That is the plan anyway. But, seeing as I spent this evening completely rewiring my dash so I could move my PCM out of the cab to see if it would reach my core support, my plans change alot.
Rex |
#381 | |
Still Learning
My wiring is no where near complete so I have flexibility. I just thought it would help clean up the engine bay if it's in the cab. I am leaning toward braided stainless too with AN-6 fittings. Not sure yet. I've also thought about inline tube's stainless "oem" prebent lines. I think they will be a pain to install based on my brake line experience. How about some wiring pics? |
#382 | |
I would be glad to show some pics but like I said now my wiring is torn apart again.lol and besides... the last time I showed you wiring pics you got your engine started before me! ![]() ![]()
Rex |
#383 |
Didn't like the PCM outside either so I tried something different back inside the cab.
I modified the brake booster bracket so the wires for the PCM would reach father. ![]() ![]() Then I bent some metal for a bracket to hold the PCM. ![]() and attached the bracket. ![]() Then mounted the PCM ![]() ![]()
Rex |
#384 |
thats cool , tucked away but easy acces !!!!!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#385 |
GEARHEAD
Good idea!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#386 |
![]() Join Date: Jun 2011
I like that. Looks good Rex
Posted via Mobile Device |
#387 |
Still Learning
I like what you got going there Rex. I hope you made a few of those brackets
![]() Merry Christmas! Posted via Mobile Device |
#388 | |
Thanks raull, I hope it is easy access, things are getting tight in there! lol
Thanks Quote:
Thanks Mike, I would be glad to get you one anytime, but with your metal skills you could fab a bracket that would make me want to throw mine away! lol
Rex |
#389 |
Need an opinion...
My tranny was hitting the bottom of my cab, so I lowered the rear end of the tranny to allow some room. That of course tilted the motor toward the firewall. Do you think it tilts too far? The only option I would have is to raise the tranny back up and put 1/4spacers under the cab mounts. ![]() ![]() ![]()
Rex |
#390 | |
Still Learning
Not sure about the spacers? Any chance you could shoot some pictures of the bottom side where the interference is? I have had this fear since I have a low hump in my "new" cab. If you use spacers, you'll have to raise all of the other parts too right? fenders, bed? Your motor looks great! where did you score the headers? maybe I missed it? |
#391 |
Looks like you have tons of room up front. Can you move the entire drivetrain up and inch or so?
#392 | |
No you didn't miss the headers I just have been lazy about posting. I got them from Shon, they are the Doug Thorley's ![]() sooo shiny!! Of course with my home fabbed brackets they sat a little to low ![]() But I "massaged" the frame with a grinder and everything fit. ![]() Honestly that pic makes it look closer than it is actually. ![]()
Rex |
#393 | |
![]() ![]() Actually, I don't think moving forward will help the shallowness between the cab and tranny. But that is a good idea though... I am gonna double check and make sure.
Rex |
#394 |
It does not look that bad to me but I would want to put and angle finder on your drive shaft to see where the u joints are. Could cause a vibration if the trans is to low.
#395 |
GEARHEAD
Based on the other LS builds I've seen, tilting it back several degrees seems to be the norm. In fact, yours seems to have less tilt than most.
#396 |
67cheby
![]() Join Date: Sep 2008
can you just add the high hump ? or is yours a high hump, that would seem like the easiest solution, you can usually pick one up for 50-60
#397 | |||
![]() As I lay on my back, looking up at that tranny last night I thought man a high hump cover would take care of all of this. ![]() The main thing is that I already have my carpet but I guess... Wait a minute... are you trying to turn my truck into an 8 year build? lol
Rex |
#398 |
67cheby
mmmuuuuuuu hhhaaaaa hhhaaaaaa......evil laugh ! on a side note those headers are just plain SEXY !!
#399 |
Still Learning
Rex,
Those headers are awesome man! I'm sure you will figure out the clearence issue. I would like to take some measurements on mine before I mount the cab on the chassis. |
#400 | ||
wait thats not right.
Rex |
