Old 02-01-2012, 09:40 AM   #1
1972RedNeck
1972RedNeck's Avatar
I Have To Drive The Ford Today
Yesterday when I went to start my truck it wouldn't. It sounds like it only is firing on one cylinder. It has gas to the carburetor, and I have switched carbs. I think it has something to do with ignition. It has HEI. When modules have gone bad before, they won't fire at all. Could the coil be bad? Any other ideas?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-01-2012, 09:48 AM   #2
mpotts64
mpotts64's Avatar
Re: I Have To Drive The Ford Today
Mine did the same thing when I forgot to run a new 12 volt dedicated wire to the hei and get rid of the restricted wire. Put in a new 283 and forgot to run the wire, it lasted about 600 miles then it was on, no more run. Ran a new wire and runs like a sewing machine.
No one ever fell to the top of a mountain.
When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend -
mpotts64 is offline   Reply With Quote
Old 02-01-2012, 11:04 AM   #3
grancuda
grancuda's Avatar
Modules will do a partial fire.
grancuda is offline   Reply With Quote
Old 02-01-2012, 11:50 AM   #4
1972RedNeck
I did run a new wire after I had the same problem.
I carry a spare in the toolbox. I'll swap it in and try it.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 02-01-2012, 12:18 PM   #5
68gmsee
Active Member
68gmsee's Avatar
I guess anything is possible but I've never had a module partially fire.
It's easy enough to check if all the wires are firing with a spare plug and clamp grounded to the engine. Or, a timing light clamped to the wire while cranking.
Also check for pin hole in rotor, loose crimps or loose electrical connections.
68gmsee is offline   Reply With Quote
Old 02-01-2012, 01:52 PM   #6
awbrown
Using the "F" word on the Chevy forum..Can't believe you didn't walk to work , now you made a fool of your self.. LOL
awbrown is offline   Reply With Quote
Old 02-01-2012, 06:36 PM   #7
57larry
why do you even own a ford?
57larry is offline   Reply With Quote
Old 02-01-2012, 07:00 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Alright guys, he didn't have to say he drove the F@rd. He could have just posted the problem. The way I understand it seems that he's disappointed in having to drive the F@rd.
Now it's time to help him with his problem. It's a legitimate post and he want's some answers.
Old 02-01-2012, 07:08 PM   #9
1972RedNeck
Correct. I like driving my GMC whenever possible. My ford is my work truck. My grandpa bought it new in '66. It has sentimental value.
I tried running a wire directly from the battery to the dizzy (still dead). I will go inspect the cap/rotor and swap modules.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 02-01-2012, 08:13 PM   #10
DT1
DT1's Avatar
I have a Delco HEI in mine and the modules fail often. All of the failures occur after I shut the engine down. It's such a common occurrence, I know if I crank the engine for more than 10 seconds, it means the module is dead. I have tried every brand of module out there and none seem to be any better than others. I always keep a spare module in the truck.
A few months back I installed a PerTronix D2070 Race Module. It only draws 7.5 amps and it has actually lasted at least 3x longer than any other.
DT1 is offline   Reply With Quote
Old 02-01-2012, 08:58 PM   #11
1972RedNeck
Just swapped in the module. Runs like a top. I only have about 1,500 miles on it. I used lots of dielectric grease too. I wonder if we can buy USA ones?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 02-01-2012, 10:26 PM   #12
awbrown
Most of the time if it is eating modules , it means something is not up to snuff.. marginal wires , cap rotor , something is taxing the system and the module is the first thing to go ....
Old 02-01-2012, 11:16 PM   #13
DT1
DT1's Avatar
Dielectric is not what you want. You need heatsink grease. From what I've read, the failures are caused when the heat builds up during long periods of idling or after the engine is turned off and the heat builds up on the contact plate.
I'm also quite sure nothing is amiss with my wiring.
Old 02-01-2012, 11:52 PM   #14
1972RedNeck
They send a tiny little packet of grease with the modules. This must be heatsink grease? It barely cover half of the bottom so I used dielectric grease assuming that is what was in the package.
Where can I buy heatsink grease?
My wiring is up to par. The cap and rotor are new too.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 02-01-2012, 11:59 PM   #15
GRX
GRX's Avatar
Dielectric = non-conductive. The stuff included acts as a sealer and meant to be applied sparingly. Which is why they give you such a small amount.
Heat sink grease (aka-thermal grease) can be had many places. There a Radio Shack near you? http://www.radioshack.com/product/in...ductId=2102858
And I own a Fox Body Mustang by the way. In addition to what's in my sig.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 02-02-2012, 12:03 AM   #16
mud.man.rj
mud.man.rj's Avatar
Your throwin me off thinking with the f word, if not module chech the pickup coil wires, one could be broken and "just" contacting, happened to me and it sounded like one cyl firing.
mud.man.rj is offline   Reply With Quote
Old 02-02-2012, 04:15 AM   #17
RanchTruck
Make sure the ground strap between the coil and the middle pin of the connector coming up from the module is there.
The coil is strong enough to arc the inch and change from it's body to the connector pin without that ground strap, but that will kill coils and modules.
The missing ground strap and missing heat sink grease are the two main killers.
RanchTruck is offline   Reply With Quote
