#26 |
Re: What year motor?
Verifying the VIN of the vehicle that the engine came from is the easiest way.
8th vin digit U.....LQ4. 8th vin digit N.....LQ9. Ive had wreaking yards try to pass off LQ4's as LQ9's. I made a jumper/patch harness (PCM plugs with power, ground & data link connector) & use my Tech 2 to read the VIN thats in the PCM. |
#27 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#28 |
Boosted Member
I use EFI Live to do the segment swap to go to 80e or manual trans, and I've always had good luck interchanging pcms from V6 trucks/vans to other LS vehicles.
Painter, I've recently acquired another spare 0411/DBC TB/harness. PM me if interested. Posted via Mobile Device
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#29 |
Alright got another question.
The trans. I got came out of a truck its a 4l60e does it matter what year it is? The Escalade my motor came out of was AWD that's why I didn't get the trans. out of it. Also, I don't see any way to access the torque converter bolts am I not seeing something?...............Forgive my lack of LS experience
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#30 |
It matters to an extent, but as long as it's a '99 up you shiould be ok. Do you know what year it is? And to access the torq converter bolts you have to take the starter off and the plastic shield behind it.
#31 | |
#32 |
I was wrong I looked it up and the trans. is a 2000, it should still work fine .....right?
#33 |
Yes.
#34 |
There are 298mm & 300mm versions, 4.3 & 5.7 Vortec's have 298mm 4L60E's
All LS based engines with a 4L60E use the 300mm version. |
#35 |
Doh! I was thinking V8 2000 pick up when he said it was a 2000. I didn't think about a V6 truck, or the possibility it came out of a van.
#36 | |
#37 | |
ID info.... |
#38 | |
Thanks found the info on page 6!!!!
