Old 08-31-2013, 12:59 PM   #151
Lattimer
Lattimer's Avatar
Re: Lattimer's 1970 C-10 build
Valves seemed to have some issues going on. It had been smoking now and then, and always had a little bit of a pop out of both exhausts at idle.
Engine is kind of a greasy mess.
Both engines sitting in the garage. I have to swap the intake and the P/S pump over to the new one before installing.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 09-04-2013, 09:38 PM   #152
Lattimer
Lattimer's Avatar
New engine in the truck tonight. Still a lot of work before it runs. Orange looks so much better.
Shawn
Old 09-04-2013, 10:06 PM   #153
Mister-B
That's a beauty, man
Mister-B is offline   Reply With Quote
Old 09-04-2013, 11:13 PM   #154
Lattimer
Lattimer's Avatar
Thanks. Once I get everything back in with the new shiny headers it should look even better.
Shawn
Old 09-05-2013, 07:55 AM   #155
mcbassin
Still Learning
mcbassin's Avatar
Awesome looking new engine!
Old 09-06-2013, 09:50 PM   #156
Lattimer
Lattimer's Avatar
Thanks!!!!
Shawn
Old 09-06-2013, 09:52 PM   #157
Lattimer
Lattimer's Avatar
Got the headers in between last night and tonight. Amazingly, they fit perfect with no issues, cleared the motor mounts and the crossmember. Couldn't believe it.
These are supposed to be the same as the ones I took out, and they look identical, but the old ones hit the passenger side motor mount and the PO had dented the header for clearance.
On the flip side-----these did not clear the z-bar the same as the old ones. So I'm in progress of re-designing the z-bar to fit better. As long as I can weld it, I can't be stopped!!!!! LOL
Shawn
Old 09-08-2013, 10:51 PM   #158
Lattimer
Lattimer's Avatar
Z bar fits and works now. Got the alternator and Ac compressor mounted, carb i son, radiator in.
Made 3 trips to Auto Zone before I got a set of belts that actually fit. New pulleys caused me to have to get slightly shorter belts, and I guessed wrong twice.
Spent a bunch of time fixing and cleaning up wiring. Put a lot of the wiring into black wire loom and routed and taped it. Looks a lot better and hides the rainbow of wire going everywhere. I have too much extra electrical stuff to hide it all.
Also found my newest fuse holders for the electric fans melted just like the last ones. Fuses weren't blown, but the holders looked like they had been torched. Rewired that and installed a car audio style fuse block with the big glass fuses. If this melts I give up.
I still have to get clamps for the lower radiator hose (forgot them all 3 trips today), fill with coolant, install trans and driveshaft, and wire the starter.
Shawn
Old 09-08-2013, 11:05 PM   #159
Mister-B
Looking good. While you've got the hood off, it'd be a good time to paint your hinges, as well as your brake booster/MC/bracket with that Rustoleum hammered spray paint you turned me on to. I just installed a brand new booster and MC, and apparently they just primer them, and they're subject to rust
Old 09-09-2013, 08:36 AM   #160
Bennett68C10
Bennett68C10's Avatar
Nice job on the engine swap, your right the orange looks much better
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-09-2013, 02:23 PM   #161
Lattimer
Lattimer's Avatar
I have to see if I can clean the hinges up enough to paint them. They probably need to be blasted.
The booster I already painted with Eastwood Brake Parts paint, its supposed to be resistant to brake fluid. I have a new master going in soon when I do the rear brakes, and I already painted that as well.
Shawn
Old 09-09-2013, 02:24 PM   #162
Lattimer
Lattimer's Avatar
Thanks. Now I just hope it runs!
Shawn
Old 09-15-2013, 05:18 PM   #163
Lattimer
Lattimer's Avatar
New engine is alive! Got it fired up today. Broke the cam in, got most of the tuning set up. Few minor issues to address still, but so far I did it right.
crappy video's are here: http://67-72chevytrucks.com/vboard/s...d.php?t=596848
Shawn
Old 09-15-2013, 06:46 PM   #164
Mister-B
Awesome!
I tied to view the videos, but yeah- the screen grab is poor quality, and I can't get them to play.
Brother, you need to quit spending money on that truck, and get yourself a good phone lol
Old 09-15-2013, 08:13 PM   #165
Lattimer
Lattimer's Avatar
Awesome!
It was my buddy's I phone. The videos look fine until I upload them to photobucket. Then one turns sideways and they both look bad.
Shawn
Old 09-15-2013, 08:36 PM   #166
Mister-B
Go treat yourself to the Galaxy Note 2 (or wait a month or so for the Galaxy Note 3). Bigger guys like us can pull off using such a large phone. Plus, we don't wear skinny jeans lol
The screen is large enough that you can look at service manuals, part schematics, etc. while you're under your truck too
Old 09-15-2013, 08:58 PM   #167
Lattimer
Lattimer's Avatar
I have a company supplied iPhone that I don't have to pay for, so I'm good to go. I also have a tablet I use in the garage for searching out info.
Shawn
Old 09-15-2013, 09:53 PM   #168
Lattimer
Lattimer's Avatar
Better videos
http://youtu.be/9hnB7kjqElk
http://youtu.be/vNCMeASnjXw
Shawn
Old 09-17-2013, 10:56 PM   #169
Lattimer
Lattimer's Avatar
Got the valve cover oil leak fixed last night, and got my temp gauge working tonight. Still waiting for a replacement high torque starter so i can actually crank this thing over reliably. Regular old rebuild Gm starter just can't quite do the job.
Also added some bling under the hood.
Shawn
Old 09-17-2013, 11:41 PM   #170
Mister-B
Cool videos. Engine sounds great, and you guys are having way too much fun. I can practically see the little old Italian Jersey women baking lasagna, and hearing you roll by with no hood, wondering what all that "racket is" Lmao
That top cover above the grille support looks good
Old 09-18-2013, 08:44 AM   #171
Lattimer
Lattimer's Avatar
Thanks. Got that from GMC Paul's. It covers up the ugliest part of the engine bay.
Shawn
Old 09-18-2013, 10:16 AM   #172
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
That engine turned out great! Looks good in there.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-18-2013, 10:47 AM   #173
Lattimer
Lattimer's Avatar
Thanks!
I still have more wiring clean up to do in the engine bay to get it as clean looking as I can. The additional of the AC and electric fans added a whole lot of extra wire
Shawn
Old 09-19-2013, 08:52 PM   #174
Lattimer
Lattimer's Avatar
Got the high torque mini starter in tonight. Wow is that different. I took a quick video of it on a dead cold start. 2 pumps of the gas and then I cranked it with my remote trigger.
http://youtu.be/6obJRtfbF-4
Shawn
Old 09-19-2013, 09:09 PM   #175
Lattimer
Lattimer's Avatar
Also added a 10 ohm resistor to the wire to the coolant sensor, now normal operating temp has the gauge reading in the middle of its range. Before it read hot when the engine was at 190.
Tomorrow I have to re-do a header gasket. Can't get the leak on #3 to stop.
Shawn
