Old 11-20-2013, 01:43 PM   #1
Jerryrig
Jerryrig's Avatar
Stock GM 20s
I haven't been able to locate a picture of a 67-72 c10 with a set of stock gm 20 inch wheels on it. So I decided I would reach out to my fellow forum members to see if you guys have seen, or maybe have a picture from a get together/car show, or if any of you own a truck with newer style stock 20's
The reason I ask is because these rims will become available to me in a short while and I'm wondering how they will look.....I'm also thinking about having them powder coated black like the wheel in the pic
1970 Chevy C10 Fleetside SWB
1998 Dodge Viper RT10
1999 Harley Road King
2006 Ford F250 CC SWB
2008 GMC Yukon Denali
My Build Thread
Jerryrig is offline   Reply With Quote
Old 11-20-2013, 04:19 PM   #2
lowphat53
Re: Stock GM 20s
I think it is a cool idea and I've seen escalade wheels on an older C10, however there are offset issues and possibly other things that I am not aware of. You will most likely have to run a 2" adaptor or something along those lines to even get close to running newer style wheels. So that may be something to think about. I am sure others know more about this than I do, so I am interested in hearing what they say! Good luck if you decide to go that route, be sure to post photos.
lowphat53 is offline   Reply With Quote
Old 11-20-2013, 04:24 PM   #3
mmiddle
mmiddle's Avatar
Re: Stock GM 20s
The 99 up wheels have a small center hole that will not fit our trucks. The lug spacing is the same. You can modify your hubs for these wheels, but few are willing to do it.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-20-2013, 04:54 PM   #4
hugger6933
Re: Stock GM 20s
I built a GMC with factory 20's it was a 04 I think. I was a little different truck cause it was a 2wheel drive but had the same frame as the 4x4. It had the torsion bar front suspension. I had not noticed any other truck with the front like that at that time I mean a 1/2 ton 2 wd. The 20's on it were different than the SS type wheels you are showing. To get a pic of them I don't have one saved, go to car-part .com and look up a 20 inch wheel for a 04 Sierra and you can get a pic that way. They were nice looking wheels. Jim
hugger6933 is offline   Reply With Quote
Old 11-20-2013, 05:36 PM   #5
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
I didn't know that about the center holes......are you talking about modifying the knuckle part of the rotor that comes out from my disc brake conversion in the front. Or do you only have to modify it if it has drum brakes.
And here is some info on the rims I found online....
SKU#: SET-CV83-20085-6550-31P
WHEEL SIZE: 20x8.5
WHEEL OFFSET: 31
BOLT PATTERN: 6-139.7
HUB SIZE: 78.1
BACK SPACING: 5.97
CENTER CAPS: Center cap included, factory center cap will interchange.
LUG NUTS: Discounted lug packages available 1-866-273-3651
Old 11-20-2013, 08:00 PM   #6
elf w/capital T
Re: Stock GM 20s
They would look sweet!
elf w/capital T is offline   Reply With Quote
Old 11-20-2013, 09:12 PM   #7
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
HELL YEA!!! That's what I'm thinking
My Build Thread
Old 11-20-2013, 09:12 PM   #8
hugger6933
Re: Stock GM 20s
Also the best I remeber the GMC's and Chevrolets had their own center one with a bowtie and the other GMC stamping. The wheel center itself would be opened up to fit the old hubs is the way I am understanding most have done to make the newer wheels fit the older trucks. Jim
Old 11-20-2013, 09:13 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Stock GM 20s
The stock hubs stick out with the dust cap on them. The flat center cap want work unless U modify the wheel are the hub. The wheel center hole is smaller on the new wheels as well it would have to be opened up to get a good mount are as stated us some spacers.
I like the polished 20" Tahoe wheels also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-20-2013, 09:25 PM   #10
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
Ok...I guess it is possible then with a spacer and a little work....it sure beats paying out the @$$ for custom billet wheels right now. Lol!
My Build Thread
Old 11-20-2013, 09:56 PM   #11
cool68
Re: Stock GM 20s
with the data that you have on the rims take the time to do some measuring to help find out what you problems you may face. get the data on tires planned to run also, include some extra width for inflated tires. can do partial mock up with pieces of plywood.
cool68 is offline   Reply With Quote
Old 11-20-2013, 11:12 PM   #12
lowphat53
Re: Stock GM 20s
Wouldn't the adaptors help with the center bore issue if it provides an extra 2" of clearance?
Old 11-21-2013, 12:22 AM   #13
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
That's what I'm thinking.....it should clear the round castle nut cap, right??
My Build Thread
Old 11-21-2013, 09:44 AM   #14
lowphat53
Re: Stock GM 20s
I would think so, maybe if anything order a pair of 2" adaptors and if you have any friends with newer wheels they can let you borrow at least 2 for back/front to test fit and see if there is any issue.
Old 11-21-2013, 02:15 PM   #15
sterk44
sterk44's Avatar
Re: Stock GM 20s
Check out this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=221042
Post #13
He mentions the issues people are talking about here... but at least there's a picture. only one I could find.
Drew
1970 C10 LWB Daily Driver
1971 Nova
sterk44 is offline   Reply With Quote
Old 11-21-2013, 04:57 PM   #16
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
Post #13
THANKS! That is extremely helpful. I think I'm going to go ahead and pull the trigger when my buddy is ready to sell them to me, after he gets his new wheels. I think they look sweet on that truck. But still wish I could see them on a completed truck....maybe I should see if somebody can photo shop the black rims on a lowered blue truck...
Does anybody know somebody on the forum I should contact to get it done? I am horrible at Photoshop. Lol!!
My Build Thread
Old 11-21-2013, 06:23 PM   #17
sterk44
sterk44's Avatar
Re: Stock GM 20s
Post a picture of your truck and the wheels you want in the photoshop forum here: http://67-72chevytrucks.com/vboard/f...splay.php?f=33
Those guys have some real talent... I'm horrible too. better off just holding up the two photos next to each other and trying to imagine what they'd look like together. lol
Drew
1971 Nova
Old 11-22-2013, 10:00 AM   #18
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
OK, sweet.....I will go over there to see if they can get it done...since my truck isn't painted yet, I did a Google search and found a truck that they can hopefully do it on.
My Build Thread
Old 11-22-2013, 10:14 AM   #19
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
Here is the thread started in the photo shop area.....hopefully somebody is angle to do it
http://67-72chevytrucks.com/vboard/s...21#post6382921
My Build Thread
Old 11-25-2013, 11:46 AM   #20
Jerryrig
Jerryrig's Avatar
Re: Stock GM 20s
So here is an update....
Nobody replied to my request over on the photo shop side of the forum, so I went over to another forum and was able to get it done.
I like the way it looks.
My Build Thread
