Old 03-08-2014, 03:42 PM   #1
SCOTI
SCOTI's Avatar
Re: Servicing the rear end hubs on a dually
Originally Posted by franken View Post
Sounds like you know what you're doing, but didin't try the cold, hot part, or getting the parts lined up 1st.
Well the cold/hot would have taken some doing since I don't personally have an oven or a grille. I planned to use a propane torch for the heat & put the races in a deep freezer overnight tonight if things didn't go well this morning. Every time I attempted to knock the race into place, the 'tool' was as plumb/vertical as possible so my 'alignment' was correct.
But..... They're installed. The right tools make a BIG difference w/the installation. No changes on installation technique. No changes in my 'procedure'. I even had to show the tech @ my buddies work the order of assembly (he said it had been 10+yrs since he'd messed aroung w/C30 hubs). A few good whacks using his driver vs the aluminum store brand unit & it was in. I did use the alum driver to knock it in further (to the point the snap ring could be installed)....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-11-2014, 10:50 PM   #2
SCOTI
SCOTI's Avatar
Just a couple follow-up questions.....
If I understand correctly, the rear hub bearings are done similar to how the front spindle/hub bearings are done:
  • Tighten the bearing nut down to recommended specs (50ft/lbs in the case of the Dana 70hd rear according to my service manual) while turning the hub.
  • Back off the nut until loose enough to turn by hand but not exceeding 1-notch on the nut.
  • Align the closest notch in the nut w/the keyway on the axle tube.
Sound right??
And....
The new-drum/rebuilt hub assemblys were re-installed over new brake shoes & hardware. The adjusting nut for the shoes on both sides are adjusted 100% in. There is zero drag on the pass side & moderate drag on the drivers side. I backed off the tension rod for the e-brake & it sure seems loose but there's still some drag @ the drum.
Am I missing something here as far as adjustment? I'm extra concerned because this side was the worst of the 2 as far as material remaining on the shoes (all friction material was gone & it was metal to metal contact before servicing).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2014, 04:04 PM   #3
SCOTI
SCOTI's Avatar
Originally Posted by SCOTI View Post
And....
Figured this one out.... I had backed off the adjustment rod for the e-brake (from it's original position) when the rear end was re-installed. The more I kept thinking about it, I decided that would be the easiest item to 100% eliminate from the possibilities. I backed off the tension nut completely @ lunch today & there's zero drag on the driver side now.
Glad I checked this 1st. My 2nd choice was to disassemble/remove the hubs from the rear end & swap them side-to-side to see if the issue followed the drum/hub or stayed on the drivers side. Much less work
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
