![]() Join Date: Oct 2009
Re: Converting to Power Steering 68 c10 6cyl
Looks good! I think you've definitely got the hardest part knocked out.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
#2 | |
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#3 | |
I'd like to get it off then modify the fender bracket. and bolt it up. Do you know where I can source a the nut that goes on the end pittman arm and holds of the tie rod? The one that came off the manual box goes on and then it stops, I didn't want to mess up the threads. I might try using a wrench to tighten it up to see if it works or not. Also on the ps gear my manual only had 3 bolts holding it on, do I need to have 4 bolts for the ps gear? It would make since to have all 4 bolted down.
#4 | |
I'm not sure if you can buy just the nut. I can't imagine the threads being different, but I'm not sure. I'd spend a few minutes cleaning up the threads....a thread file can work wonders if they are messed up a little. Of course, you should get a new nut if you use a new one pitman arm. I'm sure I have one or two laying around if you really end up needing one. I would definitely recommend using 4 good grade 8 bolts to mount the steering box.
#5 | |
Don't forget that you can go to one of the parts stores and borrow tools such as pitman arm pullers and pickle forks
#7 | |
STRANGE THING happened my steering wheel makes a grinding noise when I spin it around. What do you think caused this? Could my steering wheel bearing possibly be out?
I don't know what to tell you about the steering wheel.
