Old 05-23-2014, 12:06 AM   #1
chevymadness
Re: Why is my truck such a *****
Originally Posted by tucsonjwt View Post
If an alternator and starter were all you put into your C10 you are doing very well. Prices for rebuilds or even new AC Delco on those parts are cheap. A 1/2 ton can haul a lot if it is geared properly, but as has been said, stopping and handling with the relatively lightweight suspension and frame are an issue.
In my mind, a 1/2 ton is built more like a car, and a 3/4 ton is heavier all the way around - from the front suspension to the rear axle. I think it actually weighs about 1000 lbs. more empty with all that gear on it. Of course, 3/4 ton gas mileage is terrible compared to a 1/2 ton.
We'll I wouldn't want a 3/4 ton I would want a 1 ton at least what the hell can a 1 ton do other then waste more gas to load albertsons groceries!
The weight I would see a decent truck to pull is 6500 pounds to 8000 I plan to have a reliable truck that can haul jetskis and crap around.ahell the newer v6 Chevy models pull more weight this is a joke!
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 05-23-2014, 09:46 AM   #2
imjeff
imjeff's Avatar
How many jetskis are you towing? They weigh around 800 per ski and can be towed by a C10 or a car for that matter.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 05-23-2014, 01:13 PM   #3
crashz
crashz's Avatar
Re: Why is my truck such a pain
For a reference, I had a 2004 GMC Sierra, long bed, regular cab, 4x4 with 5.3 V8 and 4L60E automatic transmission. Great truck. I loved it for 7 years, maintaining to perfection, but using it as well. 180K miles, towing, plowing snow and commuting.
The only thing it could not do well was tow. It was rated for 8900lbs, but my 5000lb trailer loads would make the chassis flex, rear suspension squat and generally wallow in turns. It had plenty of power, and adequate braking, but the chassis was not enough. I tried a few upgrades with some positive results, but it never felt right. Upgraded to the 2500HD in 2012, and its a world of difference. Its also almost 2500lbs heavier! And gas mileage is terrible. But towing is easy-peasy!
The lesson is tow/load within the legal ability of the truck and to where you feel comfortable.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 05-30-2014, 01:15 AM   #4
chevymadness
Does anyone have any information on a 1 ton because I plan to buy a 1 ton I would want to buy a boat and hopefully a 1 ton can pull about 6500 pounds and maybe 2 jet skis 800 pounds a piece.These trucks are fantastic at carrying quads I can literally fit 4 atvs in new trucks that's impossible.
Old 05-30-2014, 09:10 AM   #5
Ziegelsteinfaust
My C20 with the camper special package was rated at 9000 or 10,000 pounds. A regular C20 was either 8000 or 9000, a crew cab dually can do 11,000, and a C30 rclb is 10,000 pounds. Provided your running E rated tires. I have had 2800 pounds of scrap in the back of my C20, and it actually rode nice. Barely dropping the rear end an inch.
If you plan to lower your truck just use C30 parts.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-30-2014, 09:58 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
It like a have my cake and eat it too thing not usually gonna happen. What kind of boat? it should have no problem towing a normal boat and jet ski, i tow with my 85 k10 alot and it does fine. As for replacing alternators and starters that's nothing compared to a new truck payment that will also break down sometime or another. I am way ahead from driving older stuff vs car lot new i haven't had a truck payment in years and my trucks don't require that much $$ to upkeep.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-31-2014, 07:31 AM   #7
Desert1957
Desert1957's Avatar
You might want to fix your truck before you start a thread about the lack of towing capabilities of ALL square-bodies.
Here is mine working, no problems at all towing or braking. It was a lot less then buying a brand new 2014 Dually.
Name:  P6080864 - Copy.jpg
Desert
Desert1957 is offline   Reply With Quote
Old 05-30-2014, 01:26 AM   #8
imjeff
imjeff's Avatar
Sounds like your tongue weight was way high!
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
