Old 12-03-2014, 10:44 PM   #1
Gregski
Gregski's Avatar
What carb base gasket should I use?
I did not realize I would have to give a second thought to which base gasket to use with a Holley 4160 carburetor and the Weiand 8120 intake manifold, but now I see there are at least three choices.
This is what the intake looks like and the three base gaskets.
A. 108-10 one square hole
B. 108-18 two oval holes
C. 108-58 four round holes
Which one would you recommend and why? Please be kind I am honestly trying to learn something here as I honestly do not know the benefits or limits of each?
Gregski is offline   Reply With Quote
Old 12-04-2014, 12:48 PM   #2
Caleb
Caleb's Avatar
Re: What carb base gasket should I use?
i use the square bore intake gasket. the first one. why? i dont know id have someone smarter than me shed some light on that one.
Caleb is offline   Reply With Quote
Old 12-04-2014, 01:56 PM   #3
bnoon
Match the intake manifold. Single plain uses the open style, dual plane the split. Usually only the old school or stock replacement style manifolds use the 4 hole.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 12-05-2014, 12:51 AM   #4
Gregski
Gregski's Avatar
Thank you Holley Tech Support gave me the same recommend, see below.
"Hello,
Thank you for contacting Holley Performance Products. Personally I would suggest an open plenum gasket - 108-10.
Sincerely,
Colin Kinser
Holley Technical Service"
Old 12-05-2014, 12:58 AM   #5
GMC Guy
GMC Guy's Avatar
throw a 1" phenolic carb spacer on there while you're at it
http://www.summitracing.com/nv/parts/sum-g1412
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 12-05-2014, 01:02 AM   #6
Gregski
Gregski's Avatar
you know me and a buddy of mine were at this place in town called Tognotti's Auto World and he said the same thing, I honestly don't know what the pros or cons of such implement are yet so I don't want to get a hernia trying to figure it out, that and start WWW III with a discussion here about those things, LOL
Old 12-05-2014, 01:30 AM   #7
GMC Guy
GMC Guy's Avatar
well, not trying to spark any debates, but it solved a hot start issue with my truck after converting to an aluminum intake and edelbrock carb. the carb would get "heat soaked" after shutting it off for say 30 mins to an hour. I know you're going with a Holley (I spied on your build thread haha) but I'm sure the materials used to cast the carb body are similar.
Anyway, I tried the 1" phenolic spacer (4-hole) and *Poof* problem solved
plus, it did add a little power off the line...
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 12-05-2014, 08:36 AM   #8
Koffer
I would call the tech support of the company that made the manifold , not the carb manufacturer .
If it was me ,I'd use gasket 2 as it's a dual plane manifold .
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model )
Koffer is offline   Reply With Quote
Old 12-05-2014, 08:46 AM   #9
andrewmp6
Gmc guy is on point a carb spacer can save you from having heat soak in the summer.
Old 12-05-2014, 11:39 AM   #10
Gregski
Gregski's Avatar
Originally Posted by Koffer View Post
I would call the tech support of the company that made the manifold , not the carb manufacturer.
Same company, lol
I'm with you, so I emailed Holley/Weiand Tech Support back and they replied:
"That gasket will work fine also."
Kinda wishy washy if you ask me, I am the type of guy who wants to know why or why not or what the benefits are of each, know what I mean. I likes to learn.
Old 12-05-2014, 11:51 AM   #11
rich weyand
rich weyand's Avatar
If keeping the planes separated did not matter, there would be no reason to run the separator on the manifold all the way up to the carb base. Use the split gasket (#2) or the four-holer (#3).
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 12-05-2014, 12:00 PM   #12
Caleb
Caleb's Avatar
Or you can buy a heat shield for your carb. I had to trim a little off the front due to the thermostat housing but here on the coast when it gets hot it helps a lot.
Old 12-05-2014, 03:46 PM   #13
McSwine
McSwine's Avatar
I was thinking the same thing. Did wonders for mine.
McSwine is offline   Reply With Quote
Old 12-05-2014, 06:47 PM   #14
Koffer
Same company, lol
Here's a link to some learn'n
http://www.enginelabs.com/engine-tec...or-dual-plane/
Old 12-12-2014, 12:04 AM   #15
Gregski
Gregski's Avatar
Great article!
Old 12-12-2014, 12:06 AM   #16
Gregski
Gregski's Avatar
so my Holley carb arrived today and guess what gasket it came with? Thought I would just throw that out there
Old 12-12-2014, 10:46 AM   #17
Caleb
Caleb's Avatar
Now all you have to worry about is tuning it. thats the best part....
1986 K1500 Pro-Street 4x4
Old 01-01-2015, 12:31 PM   #18
Gregski
Gregski's Avatar
I concur, so I ordered the 108-18
