Old 04-02-2015, 12:47 PM   #1
6xchevy
Steering Wheel Question
Will a steering wheel off a 70's Nova,Vega etc. fit my 68 C10. Any issues with the horn, column? Thanks to all!
6xchevy is offline   Reply With Quote
Old 04-02-2015, 01:37 PM   #2
kcsa75
kcsa75's Avatar
Re: Steering Wheel Question
Yes. It should bolt right up. No problem.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-02-2015, 01:44 PM   #3
FirstOwner69
FirstOwner69's Avatar
Agree. It should bolt right up. The only glitch would be, depending on the wheel chosen, wiring the horn contact. I don't know if the Vega wheels require any modifications for the horn. I used a 94 S10 Blazer LT leather wrapped wheel and have some pics of how I wired the horn which may help depending on your wheel.
Jim
FirstOwner69 is offline   Reply With Quote
Old 04-02-2015, 08:21 PM   #4
EARNHARDT#3
EARNHARDT#3's Avatar
Don't '67,68,69 have the smaller splined shaft and later bigger? Does the same go for GM cars?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 04-02-2015, 09:28 PM   #5
hugger6933
No the wheels will work from way back[early 60's I'm sure of] to way forward to 94 and beyond the splines are still the same after the 94 model year it is just that most wheels went funky looking air-bag were installed. Jim
hugger6933 is offline   Reply With Quote
Old 04-02-2015, 10:20 PM   #6
One of the beauties of GM is so much parts interchangeability. Did you know the glovebox latches in our trucks are the exact same one as in a '55 Chevy Belair? Not only those, but just a for instance.
Old 04-02-2015, 10:45 PM   #7
EARNHARDT#3
Why do the aftermarket wheel adapters change after '69 then? That's why I thougt they were different.
Old 04-03-2015, 10:25 AM   #8
leftybass209
leftybass209's Avatar
Parts inside the column change, not the steering wheel shaft diameter, or spline count though. I just purchased a grant wheel adapter for a tilt column. The previous hub is flat on the back side, the new one has a machined recess. Same diameter, same thread count.
leftybass209 is offline   Reply With Quote
Old 04-03-2015, 12:40 PM   #9
jeffahart
jeffahart's Avatar
I'm tempted to hijack this thread to #itch about the 3 spoke grant that I sent back after one week.
I just did... consider it a public service announcement.
I'm on the hunt too. I'll be hitting the junk yards for my next wheel.
White K20
jeffahart is offline   Reply With Quote
Old 04-03-2015, 12:47 PM   #10
EARNHARDT#3
Ahhhh...gotcha! Thanks for the info.
Old 04-03-2015, 01:26 PM   #11
leftybass209
Many of us are aware of the Grant wheel problems! A much better option is just about ANY original or GM repro wheels. Their horn functionality is superior.
Old 04-03-2015, 01:41 PM   #12
jeffahart
jeffahart's Avatar
I am now also skeptical of the repos, reading mixed opinions; just like with the grant. I even made plastic flat springs so the horn would work independent of the cap cover. But the wood joints separated. I initially thought if I licked the horn issue(cap pops off horn blows) I would be good to go. Not the case.
White K20
