Old 05-08-2015, 09:33 AM   #20
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Do you have a 4WD with a 3 SPD on the colum transmission?
You'll need to keep the pivot point in the original position for the lever to go flat parallel to the floor as well as to clear the seat in the vertical position.
I'll use the top of my frame as a reference point off of my setup and the distance from the TC to guide your installation/modification.
What is the casting code on the 3SPD?
