Old 06-08-2015, 10:33 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Brush-on chassis paint - Happy with results?
I'm thinking I might brush on two coats of Bill Hirsch Black Chassis Undercarriage. I feel I can get the nooks and crannies better, and I'm pretty good with a brush. So I'm wondering, have you brushed on? Did you brush on primer as well? Were you happy with the results?
Still pondering how far I need to go on the frame, scuff Vs down to metal. I suppose I could do some research and have it blasted.......................................Not sure I want to remove the leaf springs. I figure I can get them "looking" like new anyway, and if ever they need replacing, all is equal anyway. Cutting a corner so to speak. New exhaust system though. Can't wait to see the price on that. I hear the guy is outstanding. Today I asked him what his hours were......"9am-10pm".
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-08-2015, 11:16 PM   #2
71CHEVYSHORTBED402
Re: Brush-on chassis paint - Happy with results?
Found a place that does soda blasting. Maybe I can work something out while the exhaust is off. At this point I'm just working under the "missing" bed. The rest comes later. The body guy and I are working our way forward, not all at once.
Tony
Old 06-09-2015, 08:46 AM   #3
I se Masterseries because I am really sold on it and I know they actually make their product. The owner is a chemist who used to work for POR-15 and quit to start his own company when the cheapened down the product. I recommend brushing over spraying. It self levels, as far as looks goes. You will get a better coat of finish and not miss a spot. If you hit it at all, it's a good coat. With spray, and all the blow-by and various hidden angles, you tend to miss spots or barely cover others. You find out when you see the rust later on.
Old 06-09-2015, 09:48 AM   #4
ol'blu72
I used POR-15 on my frame and engine and am happy with the results, except on the headders. I used their high temp and it is flaking off.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 06-09-2015, 02:04 PM   #5
cdowns
cdowns's Avatar
I've used brush on paint por 15 rustoleum bill hirsh and ace hardware enamel have been pretty happy with the resuls on all the progects that i've done like that and had goord long lasting results on my daily drivers
Old 06-09-2015, 04:52 PM   #6
71CHEVYSHORTBED402
Thanks again K. I'll look into Masterseries. Incidentally, I called the soda blaster today. His attitude sucks so he won't be getting my business. I may end up stripping this down the hard way.
Tony
Old 06-09-2015, 05:04 PM   #7
michael bustamante
michael bustamante's Avatar
weve all done the hard way. thats what makes us dedicated. i brushed my por-15 and it looks and survives well
1967custom
michael bustamante is offline   Reply With Quote
Old 06-09-2015, 07:43 PM   #8
blongdon
So do you paint over the nuts and bolts with this stuff? Seems it might come back to haunt you if you ever had to remove anything.
Good luck!
blongdon is offline   Reply With Quote
Old 06-09-2015, 08:39 PM   #9
notsolo
notsolo's Avatar
I also use Master series, and I like the silver. Anytime you can brush it on you will get better adhesion, you can spray on a 2nd coat of the same or top coat with just about anything including base coat. ....matter of time how far you want to get into your project, painting over nuts and bolts is not ideal but stripping down to a bare frame takes a while.....http://www.masterseriescoatings.com
notsolo is offline   Reply With Quote
Old 06-09-2015, 10:18 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Brushed on POR 15, very happy with results. Been using it well over 20 years and will keep doing so. I'm sure there are other products that are the same thing, but I'm not changing when I don't see the need.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-09-2015, 10:36 PM   #11
Dustytrix
Master series silver for me too. But I sprayed what I can and brushed where I couldn't spray. But wear gloves, even lacquer thinner won't get it off your hands.
Dustytrix is offline   Reply With Quote
Old 06-09-2015, 11:21 PM   #12
71CHEVYSHORTBED402
Good luck!
There really aren't many bolts where I'm at (bed frame). The exhaust system will be new anyway, as will the shocks. That leaves the leaf springs. Light brush strokes around the bolts should do it.
Tony
Old 06-09-2015, 11:30 PM   #13
71CHEVYSHORTBED402
Unless I can make some arrangements, I'll be stripping down the frame the hard way. Not sure on scuff Vs down to metal yet. But I did find out today I have an allotment of vacation time due me. That with the regular, it's three weeks on one week off for the balance of the year.
I'll need it too. Once the bed is done the painter will be ready for the cab. My first restoration, so I'm fairly green. This website has helped A LOT.
Tony
Old 06-09-2015, 11:52 PM   #14
71CHEVYSHORTBED402
I'm reading up on it. That may be the ticket. What did you guys use for a top coat?
Tony
Old 06-10-2015, 05:46 AM   #15
Shaky
Six in a row makes it go...
Shaky's Avatar
I used this stuff on the recommendation of a friend. It's better than regular paint, but nowhere as good as the POR-15 type stuff. For the amount of work I did, I should have ponied-up for the better product.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 06-10-2015, 10:55 PM   #16
71CHEVYSHORTBED402
I'm reading up on Master series "silver". Did you guys use their top coat or other?
Took a wire brush on drill to a few areas, the existing is real solid. But then I watched someone use aircraft paint remover on powder coat...........That's the ticket. Going down to metal, the "hard" way.
Tony
Old 06-11-2015, 12:15 AM   #17
PowerdbyChevy79
PowerdbyChevy79's Avatar
brushed on POR-15 and topcoated with John Deere Blitz Black..it came out good...no complaints from my end yet.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
