#26 |
Re: Need Help Dont No What Else To Do
had an atv that did that, but the coil sparked bc of stator position, and it jumped timing, and it did EXACTLY what yours is doin. jumped like 3 teeth. pull dist and check On that style of atv, a lil raised pad acted as the rotor on your dist, so when it struck a certian point it fired, when the timing jumped, the valves would open at the wrong time, so it sparked wrong and ran like CRAP at idle, get up in rpms and it went away, but was a lil down on power.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks ![]() Last edited by Deer_hunter_088; 01-17-2017 at 04:28 PM. |
#27 |
ok the backfire...is backfiring out the exhaust or popping back through the carb? back through the carb is typically a lean condition...what carb is on it? its possible that while cranking it when it was wet it crossfired and spit back thru the carb and damaged something...blew off a vacuum hose, damaged pcv valve or hose, power brake hose, carb gasket etc...now that its dry its running lean...also did you check the timing? if its way off or all over the place the timing chain could have skipped (original style plastic tooth ones were famous for that)...
1970 short step c10 leaf spring 454 |
#28 |
What about the coil? I had similar symptoms after running my '85 out of gas - replaced everything but the coil (the fairly expensive part) and rebuilt the carb. to no avail, but IIRC a new coil fixed it right up.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
#29 | |
Posted via Mobile Device |
#30 | |
Posted via Mobile Device Posted via Mobile Device |
#31 |
![]() Join Date: May 2013
check timing before you do anything
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#32 | |
Smoke Tires Not Drugs ![]() |
#33 |
![]() Join Date: Feb 2009
Bad distributor is my guess.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#34 |
![]() Join Date: Apr 2016
I read through the thread and don't think you mentioned yet, are you powering the HEI distributor with the stock resistor wire, or have you done the 12V solid wire modification to your wiring when you installed the HEI?
#35 |
#36 |
pulled the first plug cranked it till it shot out of first looked at the rotor and it was pointing to number one
#37 |
i did the mod to 12v
#38 |
has almost nothing to do with timing , check your timing
#39 |
#40 |
So took the truck out this morning and when it shifts or gets to a certain rpm it backfires when I keep it at that certain rpm it backfires ALOT
#41 |
#42 | |
Clean off the balancer and find it. THen check where your timing tab is. It'll be at 2 oclock or at 12 oclock. At 12 oclock you need to look behind the water pump for it. |
#43 |
Now there's a good starting point.
Let us know what it is OP.....Thanks
#44 |
had a 74 monte carlo with a 350 it had a bad cam and it backfired through carb and exhaust had 3 or 4 bad lobes on it at 85 thousand miles . not saying its it but if all else fails something else to check
#45 |
I had a similar situation last year , thought I fouled a plug so I did a tune up ( plugs and wires ) still same issue , replaced cap and rotor still the same issue , started looking into everything and I couldn't figure it out , and I tried evething before tearing into the internals , so for the hell of it I pulled all the plugs and found one that wasn't firing (new plug )replaced it with another new one and it fired right up no more issues , so it is possible to buy bad new parts .
I would also double check the to make sure all your plug wires seated properly , I've seen that multiple times . I like to feel a nice solid snap , and if it's not squeeze the connector down with some plyers for a good fit . Just a few suggestions , probably stuff you already tried , but I know how frustrating things get , some times the easiest fix is to take a step back and let some fresh eyes take a look at it , might be something stupid . Good luck . Sincerely, Doug |
#46 |
