Re: 1966 C10 Project Truck
A little progress tonight! Got the engine and tranny put together and dropped it all in the frame. A few little things popped up but nothing is a show stopper. I'll need some new exhaust manifolds, likely going with the Hooker block hugger manifolds and I'll need a new accessory bracket because my rack and power steering pump want to share the same space. I'm really happy with it!
60-66 Nut
Did you have any difficulties mating the T5 to the 5.3?
None at all. I'm only running 5 bellhousing bolts since the 5.3 has a slightly different hole pattern but that's not a big deal at all.
For the flywheel, I picked up a Sachs NFW1050 flywheel and was able to bolt my existing 11" clutch right to it. It's a metric flywheel so I had to get new pressure plate and flywheel bolts as well as open up the holes in the pressure plate for the larger M10 bolts. It all went together super easy and looks to be working like it should. |
Looking good Scott!
When are we doing an LS in the '69??
