Old 05-04-2014, 09:14 AM   #26
naphtali5725
naphtali5725's Avatar
Re: Anyone else tried to order truck rallies from Wheel Vintiques lately?
bummer, i bought a set too... i'll check the welding and post a follow up...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-04-2014, 09:34 AM   #27
rs74
rs74's Avatar
Can you order them bare (not painted) and then either have them powder coated or painted yourself?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 05-04-2014, 06:33 PM   #28
olllie
olllie's Avatar
looks like the truck rally will be coming back but with a 4.5bs not the old 5" style. part number on summit has changed.. may.9th is when they should be in stock. I have been waiting a long time for these. So don't buy my set!! LOL
http://www.summitracing.com/dom/part...5042/overview/
1987 GMC Wrangler 350/700r
olllie is offline   Reply With Quote
Old 05-04-2014, 06:35 PM   #29
naphtali5725
checked mine, WVI-37-580504 the welds are all ok, so i guess i got a good set...
My build thread...
Disabled Veteran
Old 05-05-2014, 06:38 AM   #30
naphtali5725
emailed Summit regarding the WVI-37-580504 wheels.. here is the response
Those wheels were not involved in the recall. We inspected all of the inventory when we were notified of the recall and notified anyone who purchased wheels that may have been affected.
Thank you for your inquiry,
Summit Racing Equipment
My build thread...
Disabled Veteran
Old 05-05-2014, 06:46 AM   #31
68Timber
I know the pieces fit
68Timber's Avatar
When I bought mine they showed up grey with a sticker on them that said they had a primer finish and needed a to be painted. Not what I expected since the product description said they were painted silver. I had them powder coated.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-05-2014, 07:55 AM   #32
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the ones I bought were suppoused to be properly finished evidently it was a hack job.. Earl scheib coulda painted em better
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-06-2014, 12:24 AM   #33
MoFormula
What is the proper 15x10 backspacing for a 1972 C10 lowered?
MoFormula is offline   Reply With Quote
Old 09-06-2014, 04:29 PM   #34
SCOTI
SCOTI's Avatar
That is a subjective question. I'll tell you 5"bs sets the wheel in the center of the well when using a 71-87 length housing. Change the housing to something different & the back-space needs changing.
Another guy will come along shortly & tell you he has 10's w/3.5" of back space & they work fine. It depends on how the rest of the truck is set up to give the best suggestions in my opinion.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-07-2014, 09:14 PM   #35
PEDROSKI
PEDROSKI's Avatar
Mine just in came in.
Old 04-07-2017, 04:19 PM   #36
akdg87
akdg87's Avatar
ive been eyeing these 37 series wheels, but wasnt sure if they would work with my disc brake setup (1972 C10 chassis), seeing your pics makes me assume they do? I have disc front and rear and was wondering if they were disc brake compatible. (i need 14" to clear the rotor/caliper on both the front and rear)
Summit and WV stated these were for pre 71 trucks and would not work.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 04-07-2017, 04:52 PM   #37
SCOTI
SCOTI's Avatar
I'm seeing "71 & up" in the descript for the 37 series....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-07-2017, 04:56 PM   #38
akdg87
akdg87's Avatar
when i spoke to summit tech line, they specifically stated "oops we have this mislabeled they are actually for prior to 71 trucks without disc brakes" and no one at wheel vintiques can give me a definite answer if they will clear the calipers
build thread
2009 CTSV Sedan
Old 04-07-2017, 06:18 PM   #39
SCOTI
SCOTI's Avatar
Seems WV are the only ones that can 100% verify that.
I would put money they're using the latest in rim hoops & would imagine they're doing the same as far as the centers are concerned. I've seen more than 1 disc brake equipped Chevy 4x4 w/WV 'car ralleys' which follows my trend of thought since disc brake spec'd wheels will also fit drum brake equipped trucks.
It does not make sense to utilize pre-71 6x5.5 drum brake center dimensions when disc brakes are so common (thus limiting the application variety). If you build wheels using disc spec'd centers, you only need to stock 1 type of center vs 2 (disc 6-lug center & non-disc 6-lug center).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
