Old 04-29-2018, 10:54 AM   #23
truckdude239
truckdude239's Avatar
Re: Replacement parts before install
i just did an engine replacement in my 2000 tahoe with 5.3 all i did was water pump, intake gaskets, knock sensors, remain seal and cover gasket and the valley pan gasket i installed a new pcv vavle that just had a hole drilled in it instead of the spring things inside motor had 150k on it inside was clean it runs good and makes 60 psi oil pressure at idle
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
