Old 07-25-2018, 04:51 PM   #1
bh86
Spare parts build
Picked this old thing up a lil while back and really liked it for some reason. It's old and ratty but has some character. Kind of a cool lil truck, it's the first 5.7 Diesel I've personally seen in the 81+ bodystyle. I really liked it because it was very well kept and unmolested. Previous owner had rebuilt the motor and AC system and after about 10k miles something happened with the fuel system and he didn't want to mess with it so it got parked and say for quite some time. I don't have any desire to play with the Olds Diesel but still thought it was kinda cool. I've had some extra stuff hanging around the shop and a 5.3/4L60 sitting that needed used so I decided to toss it all together for a lil run around truck. I'll update as we move along. I actually won't get too much hands on with this one but my lil brother will so hopefully I can get him to chime in and update as it moves along.
bh86 is offline   Reply With Quote
Old 07-26-2018, 01:11 AM   #2
fourspeedwagon
fourspeedwagon's Avatar
Re: Spare parts build
That’ll be fun. I got a little scared for you when I saw it was the (in)famous Olds 5.7 diesel. My grandparents usually drove Cadillacs that they bought when they were 2 years old. The bought a beautiful early 80s Eldorado- the original 5.7 oil burner blew up with less than 100 miles on it. Was being driven home from the dealer. The warranty engine lasted 8k miles. Grandpa bought it at that point and replaced it with an Olds gas burner and then it was great. Not sure what GM was thinking on that fiasco.
5.3 LS will be perfect. Have fun.
1951 GMC 250 Open Express Pickup
1968 Suburban C10
1971 C20 Olive
“People are shocked when they find out I’m not a good electrician”
Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it”
fourspeedwagon is offline   Reply With Quote
Old 07-26-2018, 01:20 AM   #3
bh86
Wow I would imagine he wasn't happy lol 😂
Old 07-26-2018, 10:28 AM   #4
andyh1956
If you were closer I'd come get that Olds engine. I can make that truck get 35 MPG! It will leak more fuel than it burns!
andyh1956 is offline   Reply With Quote
Old 07-26-2018, 12:20 PM   #5
fourspeedwagon
BH - sorry for the hijack but—-
Andy- How? I know that sometimes things get a reputation undeservedly but you’re the first that I’ve heard that is a fan of that engine. I guess you didn’t say that you could make it reliable or durable, only that it would leak but I assume you wouldn’t play with them if it wouldn’t last a while.
It’s been years since I’ve seen one of them run. I do like diesels (drive one daily) but the high compression didn’t seem to agree with that block.
1968 Suburban C10
1971 C20 Olive
Old 07-26-2018, 01:37 PM   #6
bh86
Get a quote from Fastenal it might be fairly cheap through them to ship. I don't need much out of the motor
Old 07-27-2018, 12:57 AM   #7
andyh1956
The last one I had my hands on I installed it into a '72 Ford F100. The owner worked for the County State Aid & I didn't know it at the time but his plans were to "Dip" diesel outta the motor graders & run his truck on it! Was a turbo 400 w/ a 2.75 rear axle. He told me he got mid 30s MPG back & forth to work.
Hard to believe but I've never seen one of these blown! They had the same GM glow plug problem the 6.2s had until they came out w/ the solid state glow plug relay retrofit & the advance piston bore wore out just like the 6.2 DB2 pumps. Can't say I'm a "Fan" because I like the Mechanical 6.5s MUCH better & these engines lack that thing we like called "Power"
Someplace around here I have two brand new injection pumps for the Olds Diesel.
Always wanted to rig a turbo on one after stacking a pair of head gaskets & see how it would run.
Wonder if it would fit in my S10???
Oh yeah love the "Ball Bearings In The Blender" sound they make when idling cold!
Old 07-27-2018, 03:49 AM   #8
bh86
He’s made some progress. Got the motor pulled, and cleaned and painted the frame.
Old 07-27-2018, 09:38 AM   #9
1957 Chief
Retired USAF
Dig the hydro-boost brakes.
Bubba
1957 Chief is offline   Reply With Quote
Old 07-27-2018, 01:13 PM   #10
hatzie
Moderator
hatzie's Avatar
They can be made reliable. Gutless but reliable. Kinda like the 40hp 1.5l VW diesel. In the 78-80 Rabbit.
ARP head studs and a real fuel filter/water-separator goes a long way.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-27-2018, 04:45 PM   #11
bh86
Bubba
Yes that was one of the things I really liked about it also.
Old 07-28-2018, 03:49 PM   #12
hatzie
Moderator
hatzie's Avatar
Diesel is the only way you got hydroboost on the ½Ton trucks.
Old 07-29-2018, 07:12 PM   #13
bh86
I sent my PCM of to get tuned and tuner wants to know gear ratio. The spid doesn't say anything about that as I was hoping it would. I'm assuming it's a 2.73 but does anyone know if that was or was not standard in these? I would pull the cover and check but I'm not there to do it.
Old 07-29-2018, 09:41 PM   #14
Pontiac1976
Pontiac1976's Avatar
I thinking G80 is a 3.60 locking diff
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-29-2018, 11:01 PM   #15
bh86
I was under the impression that the G80 option could be ordered with various gear ratios but I could be wrong
Old 07-29-2018, 11:07 PM   #16
andyh1956
Every C10 Diesel I ever owned had a 2.73 rear axle. Even the '82 w/ the 700R4 trans!
Old 07-30-2018, 12:42 AM   #17
bh86
Same here, I was hoping someone else would have some good news lol
Old 07-30-2018, 02:52 AM   #18
Christopher1
How to build a free metal part ans spare part.
Christopher1 is offline   Reply With Quote
Old 07-30-2018, 08:07 PM   #19
Pontiac1976
Any of these #'s on the diff does it still have a tag or stamping on the housing.
82 should be 10 bolt, has heavy load in rear. I'm guessing 350 Diesel was being set up for pulling. Did it have a bigger diff and that why it was not marked. If you can't find any # that will help then pop open the cover count teeth.
A by no means complete list, but a ball park in which to play
G80 : AXLE POSITRACTION, LIMITED SLIP
G81 : POSITRACTION REAR AXLE
G82 : AXLE REAR, 4.56 RATIO
G84 : AXLE REAR, 4.10 RATIO
G86 : AXLE, REAR, LIMITED-SLIP
G87 : RING GEAR, 8.50 INCH
G89 : RING GEAR, 7.50 INCH
G91 : SPECIAL HIGHWAY REAR AXLE RATIO 3.08
G92 : AXLE REAR RATIO, PERFORMANCE
G94 : AXLE REAR, 3.31 RATIO
G95 : AXLE REAR RATIO, ECONOMY
G96 : AXLE REAR, 3.55 RATIO
G97 : AXLE REAR, 2.73 RATIO
GH0 : AXLE REAR, 3.54 RATIO
GH2 : AXLE REAR, 2.29 RATIO
GH3 : AXLE REAR, 2.77 RATIO
GH4 : AXLE REAR, 2.92 RATIO
GK9 : AXLE REAR, 4.63 RATIO
GL3 : AXLE REAR, 6.17 RATIOG
GM1 : AXLE REAR, 2.59 RATIO
GM3 : AXLE REAR, 3.45 RATIO
GM8 : AXLE REAR, 2.56 RATIO
GMC : PLANT CODE PONTIAC, MI, USA
GN9 : AXLE REAR, 4.11 RATIO
GQ1 : AXLE, STD RATIO
GS1 : AXLE REAR, 2.73 RATIO
GS3 : AXLE REAR, 3.73 RATIO
GS4 : AXLE REAR, 3.70 RATIO
GS5 : AXLE REAR, 4.11 RATIO
GS6 : AXLE REAR, 4.56 RATIO
GT1 : AXLE REAR, 2.56 RATIO
GT2 : AXLE REAR, 2.29 RATIO
GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
GT5 : AXLE REAR, 4.10 RATIO (DUP WITH GT8)
GT7 : AXLE REAR, 3.33 RATIO
GT8 : AXLE REAR, 4.10 RATIO (DUP WITH GT5)
GTY : AXLE, WIDE TRACK
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
GV1 : AXLE REAR, 2.73 RATIO
GV2 : AXLE REAR, 5.83 RATIO
GV3 : AXLE REAR, 3.08 RATIO
GV4 : AXLE REAR, 3.36 RATIO
GV5 : AXLE REAR, 3.55 RATIO
GV7 : AXLE REAR, 4.11 RATIO
GV8 : AXLE REAR, 2.72 RATIO
GW2 : AXLE REAR, 2.56 RATIO
GW3 : AXLE REAR, 2.56 RATIO
GW4 : AXLE REAR, 3.31 RATIO
GW5 : AXLE REAR, 2.73 RATIO
GW5 : AXLE RATIO, 3.16 RATIO
GW6 : AXLE REAR, 3.27 RATIO
GW8 : AXLE REAR, 4.10 RATIO
GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3)
GWL : SPRING, RR, 9000 LBS CAPACITY
GX1 : AXLE REAR, 3.70 RATIO
GX2 : AXLE REAR, 3.07 RATIO
GX3 : RATIO,TRANSAXLE FINAL DRIVE 3.33
GY2 : AXLE REAR, 3.31 RATIO
GYS : RATIO TRANSAXLE FINAL DRIVE 3.65
GZW : GVWR: 6459 LBS. / 2930 KGS
H01 : AXLE REAR, 3.07 RATIO
H04 : AXLE REAR, 4.11 RATIO, SINGLE SPEED
H05 : AXLE REAR, 3.73 RATIO
H12 : AXLE REAR, 21000 LBS, EATON 21065S, SINGLE SPEED
HA3 : AXLE REAR, 5.29 RATIO, SINGLE SPEED
HC4 : AXLE REAR, 4.56 RATIO
HC7 : AXLE REAR, 5.13 RATIO, 7500 LBS, SINGLE SPEED
HC8 : AXLE REAR, 3.21 RATIO, SINGLE SPEED, TRUCK
HE3 : AXLE REAR, 3.07 RATIO, 3500 LBS, SINGLE SPEED,
HF7 : AXLE REAR, 4.56 RATIO, 10000 LBS, DANA 70, SINGLE
HF8 : AXLE REAR, 4.88 RATIO
HK1 : AXLE REAR, 2.87 RATIO
HK9 : AXLE REAR, 5.86 RATIO 10000 LBS, SINGLE SPEED
Old 07-30-2018, 08:48 PM   #20
bh86
[/COLOR]
I'll ask my brother if he can crawl under and look. What other diffs did they have in C10's for 81?
Old 07-30-2018, 10:29 PM   #21
bh86
These are the stamps the one that is hard to read is L110
Old 07-31-2018, 01:22 AM   #22
Pontiac1976
It's a 12 bolt gears would be 3.08, 3.42, 3.73, 4.11
Old 07-31-2018, 02:02 AM   #23
Pontiac1976
The # your looking for most times are on the front side mostly the right tube some time on the center section. They may be hard to see.
