Old 10-01-2019, 04:38 PM   #26
hemi43
hemi43's Avatar
Re: Wheel Spacers - Good thing?
Originally Posted by Blazerowner View Post
So back to my question. Any pictures with the 1.5 adapter on the rear? I would like to see the difference. I’m considering a set in the future.
I'm still planning on getting you some pictures, but been raining here non-stop so I haven't had the truck out. FWIW, the adapters in the rear makes a huge difference in looks. Before, I would be told that my truck was crab walking on multiple occasions, and then I would have to explain that the front track on Blazers is 4 inches wider than the rear which gave it that illusion. There's zero effect on how the truck drives with the adapters installed.
hemi43 is offline   Reply With Quote
Old 10-01-2019, 06:12 PM   #27
Blazerowner
Blazerowner's Avatar
Nice that’s what I’m looking for.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 10-04-2019, 03:42 PM   #28
hemi43
hemi43's Avatar
Finally stopped raining !! Here's my truck with 1 1/4" spacers on the rear.
Old 10-04-2019, 03:49 PM   #29
DeadheadNM
Carpe manana
DeadheadNM's Avatar
So with spacers you get increased deposition of road debris and grime along the body? How are these an improvement?
Old 10-04-2019, 04:16 PM   #30
hemi43
hemi43's Avatar
It's an improvement because these trucks look like crap going down the road with the front track being 4 inches wider. Road debris and grime is more of a problem with the front wheels anyway. Debris on the rear is a mute point.
Old 10-04-2019, 05:55 PM   #31
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yeah, makes perfect sense now
Old 10-07-2019, 11:22 AM   #32
Blazerowner
I hate mud so it will never see it. I don’t even drive it in the rain. It’s a summer toy for me. It does look good with the wheel spaced out.
Kirk
Old 10-07-2019, 10:01 PM   #33
simicrintz
Originally Posted by blazerowner View Post
i hate mud so it will never see it. I don’t even drive it in the rain. It’s a summer toy for me. It does look good with the wheel spaced out.
x2
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 10-10-2019, 04:16 PM   #34
mister.freeze
mister.freeze's Avatar
I thought the front was 2" wider, but I've seen 3" and 4" on this thread. Which is it?
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 10-10-2019, 10:14 PM   #35
aotte1
Agree wheel spacers are not a good product to use. If using spacers only use high quality forged alu. Do not use cast Alu or cheap forged. Also when using spacers you need to regularly check wheel nut torque. Under high loads they will loosen. This is from experience using spacers. I was taught the above by professional racing engineers.
Les
aotte1 is offline   Reply With Quote
Old 10-10-2019, 11:50 PM   #36
hemi43
hemi43's Avatar
It's 4 inches.
Old 10-11-2019, 12:18 PM   #37
SeventyOne
Swapped a 14 bolt in the rear and converted front to 8 lug. Looks even to me
SeventyOne is offline   Reply With Quote
Old 10-11-2019, 07:02 PM   #38
hemi43
hemi43's Avatar
It's amazing how much it improves the look, and no more people telling me my truck is crab walking. The only hassle was to have to remove the wheels after 100 miles to re-torque the adapter, but well worth it. Got over 1000 miles on it now.
Old 10-13-2019, 07:17 PM   #39
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
Please allow me to ask a dumb question that somewhat pertains to this subject. My drivers side front wheel sticks out 1" further than the front passenger side. There's no spacers or adapters and the wheel appears to be the same width. Is my just screwed or is this because of the steering components on the driver's side?
72' JIMMY 454
BIG BLOCK JIMMY is offline   Reply With Quote
Old 10-14-2019, 12:09 PM   #40
SeventyOne
BBJ - I think you have some issues with your axle. Especially given the info in your steering thread/posts.
Perhaps you can add some more pics to that thread and we can try to figure out what's going on?
Old 10-14-2019, 12:53 PM   #41
BIG BLOCK JIMMY
Will do! I'll put them on the other thread this evening, hopefully. Thanks
72' JIMMY 454
Old 10-14-2019, 05:17 PM   #42
hemi43
hemi43's Avatar
Measure the distance from the inside of the front tire to the side of the frame. If the measurements are the same, then this will rule out the axle being shifted to one side. I would then look at the front sheet metal being off location. (rotted/broken body mounts or rad support.)
Old 11-06-2019, 09:22 PM   #43
BIG BLOCK JIMMY
I'm getting used to asking dumb questions on here. so.... how do 1.25" spacer/adapters make up for a 3"-4" difference? I don't want to order them and they still not match the front.
I assume this is what I want? 2 Chevy Truck 6x5.5 Wheel Spacers 7/16 Thread | For 1967-1991 1/2 Ton Trucks
72' JIMMY 454
Old 11-07-2019, 08:54 AM   #44
jaros44sr
jaros44sr's Avatar
I think they were talking per side?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-07-2019, 08:59 AM   #45
BIG BLOCK JIMMY
I figured that. 1.25" x 2 doesn't equal 4" I should have asked more clearly.
72' JIMMY 454
Old 11-08-2019, 01:43 AM   #46
Blazerowner
It’s probably to just get it more in line and not use too thick of a spacer.
Kirk
Old 11-08-2019, 09:23 AM   #47
BIG BLOCK JIMMY
Thanks, I ordered 1.5" from wheeladaptersusa. If they are too thick I will give them to my wife for Christmas to use as a trivet, then order some 1.25" ones.
72' JIMMY 454
Old 11-13-2019, 09:41 PM   #48
BIG BLOCK JIMMY
72' JIMMY 454
Old 11-15-2019, 02:29 AM   #49
SeventyOne
Nice. Get some before and after shots!
Old 11-19-2019, 02:14 AM   #50
Blazerowner
What size are the studs on the adapters? I’m thinking of putting in 1/2” studs on the rear.
Kirk
